Switching between Mixes corrupts MIDI data
DP 11.04
If a sequence with automation data has active Mixes, switching to another Mix, duplicating a Mix or turning off Mix mode will cause loss of MIDI data. In my testing this meant all note data gone. 11.03 works ok which is where I am now.
Re: Switching between Mixes corrupts MIDI data
Damn — I hope you've sent this into MOTU.monty verdi wrote: ↑Tue Feb 15, 2022 2:16 am DP 11.04
Since this seemed like a bug that would be very important, I reached out directly to someone at MOTU. They were not able to reproduce this, so their suggestion was to delete the prefs shown in the image below. If it still happens, maybe you can give a little bit more detailed description of it or perhaps a recipe for making this happen.
Thanks for your responses. I will provide a more detailed soon but initially it looks like taking a snapshot is the culprit. If the mix has a snapshot in it things go awry. More anon. Cheers.
Ahh thanks! That’s probably going to be very helpful in reproducing it so MOTU can fix it!
Thanks, James, for moving this forward, and apologies for the delay in submitting this but I wanted to get a testing environment that was as clean as possible.
I did try deleting the Preference file as suggested but it did not help.
These are the steps that I used to replicate the issue on.
1 Create new project based on Empty Project template
2 Add 2 MIDI tracks to sequence 1, and addd some MIDI data to each.
(3 OPTIONAL Duplicate sequence and save for repeating the process)
4 Open Mixing Board. Select one of the tracks (Or both, but this way allows comparison)
5 Create new mix
6 Take snapshot [All time; Tracks shown in Mixing Board; Data types visible in MB: these are default values]
7 Turn mix mode off
8 Return to mix.
This step shows data loss or crashes dp completely
Alternative steps 5 & 6:
5a Take snapshot (same parameters as above)
6a Duplicate mix
Some observations:
a. it is the snapshot that initiates the problem
b. snapshot does not save Pan data correctly - it is always 64 regardless of actual setting in the mixer.
Thankyou and cheers
5 Create new mix
7 Turn mix mode off
8 Return to mix.
6a Duplicate mix
Some observations:
Thankyou and cheers
I’m having a similar problem with sound bites disappearing from a sequence when I switch mixes. If I then reopen the project, the 2 sounds that we’re missing are there. If I then turn mix mode off, and then on again, they have vanished from the track and I have to drag them back in from the sound bites window. There they will stay. Save. Reopen - sound bites still there. Change mix , they vanish. Switch back to the first mix - gone! If I then close the project without saving, when I re-open the project the missing sound bites are back! Bizarre!!!!!!
I posted a techlink and MOTU have acknowledged they can replicate the issue. It has been passed onto engineering for action. They suggested I go back to 11.03 and posted a link to download. Unfortunately the link denied me access and I’m waiting on MOTU to make it work for me. More if I hear anything. Pax y’all.
You should be able to download it at the MOTU website. Go to the Download section and choose Audio Software and Digital Performer 11. On the next page, below the picture of the DP 11 "box" you will see a button that reads "View All Downloads." Click that, and you should see a link to the DP 11.03 installer.simontassano wrote: ↑Wed Feb 23, 2022 12:17 pm I posted a techlink and MOTU have acknowledged they can replicate the issue. It has been passed onto engineering for action. They suggested I go back to 11.03 and posted a link to download. Unfortunately the link denied me access and I’m waiting on MOTU to make it work for me. More if I hear anything. Pax y’all.
Here is the direct link from that button:
https://motu.com/en-us/download-center/download/477
If the direct link doesn't work, then do the steps above.
FYI, MOTU did respond and send me a direct link to 11.03. Re-installed, mix mode appears to be functioning once again. Now to the issue that DP will often crash when I flip between PAN and SENDS on my QCON Pro G2 controller.. Thoughts anyone?
