I locked a file using the checkbox in the Get Info window.
Now I want to unlock it, and Mojave is telling me that I only have read access to the file, which ain't true. I definitely have read and write access (in fact for that folder I specified "everyone" to have read and write access). I can't even unlock the get info window for that file.
If I try to delete it, I can't because it's locked.
Help!
Thanks.
Can't unlock a file
- ghobish
Can't unlock a file
Gary Hobish
A. Hammer Mastering & Digital Media
San Francisco, Ca
http://ahammer.com/mastering
Mastering: Mac Studio M1 MAX 2TB SSD, 64GB RAM, 32-core GPU, OS 12.6; DP 11.22, Waves, Izotope RX10 Advanced, Alloy, Nectar, PSP stuff, Plug-In Alliance, Metric Halo ULN-8 MkIV, Euphonix MC Control & MC Mix, Presonus Central Station, and (still) no air conditioning (but at least now there is airflow)
Annex: Mac Pro 2010 5,1 3.33GHz 12-core, 80GB RAM, 10.14.6, DP 11.22, Metric Halo ULN8 MkIV, MOTU 2408III
San Francisco, Ca
Re: Can't unlock a file
Do you have RW privileges on the drive?
If so, right click on the file and grant yourself permissions at all levels.
I had this issue with DP 7 and files I had created on another Mac.
- ghobish
It's a few folders deep in the Applications folder of the boot drive. On this drive itself, only system has RW privileges, "wheel" and "everyone" is read only.
In the target folder itself, admin, both user profiles and everyone has RW privileges.
This is a machine in my syudio where I have a user profile for myself and one for visiting engineers/ clients. Both are admins. I am currently logged in as the visiting engineer, but that should make no difference in this case.
Gary Hobish
San Francisco, Ca
San Francisco, Ca
Apply to enclosed items or Make … the Owner. If both boxes are present, check Apply... and see if that does it. You'll get a confirmation dialog that you'll have to approve.
Highlight each User in turn. Click on the Settings I have circled in magenta. Check the box for DP 11.34; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1
- ghobish
I followed your suggestion for both "ghobish" and "engineer" (made owner of the folder and applied all changes) and am now able to unlock the file- thanks Mike!
Gary Hobish
San Francisco, Ca
San Francisco, Ca
Glad that worked!
