Can't unlock a file
ghobish
Can't unlock a file
Post by ghobish »
I locked a file using the checkbox in the Get Info window.
Now I want to unlock it, and Mojave is telling me that I only have read access to the file, which ain't true. I definitely have read and write access (in fact for that folder I specified "everyone" to have read and write access). I can't even unlock the get info window for that file.
If I try to delete it, I can't because it's locked.
Help!
Thanks.
Gary Hobish
A. Hammer Mastering & Digital Media
San Francisco, Ca
http://ahammer.com/mastering
Mastering: Mac Studio M1 MAX 2TB SSD, 64GB RAM, 32-core GPU, OS 12.6; DP 11.22, Waves, Izotope RX10 Advanced, Alloy, Nectar, PSP stuff, Plug-In Alliance, Metric Halo ULN-8 MkIV, Euphonix MC Control & MC Mix, Presonus Central Station, and (still) no air conditioning (but at least now there is airflow)
Annex: Mac Pro 2010 5,1 3.33GHz 12-core, 80GB RAM, 10.14.6, DP 11.22, Metric Halo ULN8 MkIV, MOTU 2408III
Re: Can't unlock a file
Do you have RW privileges on the drive?
If so, right click on the file and grant yourself permissions at all levels.
I had this issue with DP 7 and files I had created on another Mac.
ghobish
Post by ghobish »
It's a few folders deep in the Applications folder of the boot drive. On this drive itself, only system has RW privileges, "wheel" and "everyone" is read only.
Screen Shot 2023-09-25 at 5.32.52 PM.png (28.91 KiB) Viewed 2686 times
In the target folder itself, admin, both user profiles and everyone has RW privileges.
Screen Shot 2023-09-25 at 5.40.15 PM.png (50.2 KiB) Viewed 2686 times
This is a machine in my syudio where I have a user profile for myself and one for visiting engineers/ clients. Both are admins. I am currently logged in as the visiting engineer, but that should make no difference in this case.
Gary Hobish
San Francisco, Ca
Screenshot 2023-09-25 at 11.36.15 PM.png (154.62 KiB) Viewed 2666 times
Highlight each User in turn. Click on the Settings I have circled in magenta. Check the box for Apply to enclosed items or Make … the Owner. If both boxes are present, check Apply... and see if that does it. You'll get a confirmation dialog that you'll have to approve.
ghobish
Post by ghobish »
I followed your suggestion for both "ghobish" and "engineer" (made owner of the folder and applied all changes) and am now able to unlock the file- thanks Mike!
Gary Hobish
San Francisco, Ca
ghobish wrote: Wed Sep 27, 2023 3:15 pm I followed your suggestion for both "ghobish" and "engineer" (made owner of the folder and applied all changes) and am now able to unlock the file- thanks Mike!
Glad that worked!
