All MIDI notes rec and playback doubled [RESOLVED]
Re: All MIDI notes recording and playiing back doubled
Post by Shooshie »
Definitely not doing that here. MIDI Editing is working as always (perfectly) here.
DP 7.1, OSX 10.6.2, latest MIDI/Audio drivers.
williemyers
Post by williemyers »
MIDI Life Crisis wrote:It's sounds like the opt key is stuck...
James Steele wrote:But he's dragging and the behavior is indeed just as if the Opt key was being held down.
fair enough observation(s), but check my "MIDI editing DEAD" post and you'll see that, using the same OS, same MIDI driver on the same Mac (and keyboard), it's *not* happening with 6.03, but is with 7.02 and 7.1
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
What kind of mouse or trackball device are you using?
And okay... it's happening to you. Believe me, I'd like to get to the bottom of this because even if nobody else is having this behavior, until yours is cleared up DP will be suspect.
williemyers
hey, thanks, all. it's reassuring to hear from a couple of you that you've checked it on your systems without problems. I really didn't think MOTU would release a version with glaring mistake and I'm pretty sure now that it's something on my system - some file that, as Zed said, 7.02 and 7.1 share, but not 6.03. I'll do total reinstalls tomorrow and report back.
thanks again
~me
Post by Shooshie »
Just curious; do you use a utility like USB Overdrive which remaps your USB controls? That is, it can make any button on any device do any button-tasks?
Frodo
Post by Frodo »
All I can add to this is that when it happened to me, I realized that my keyboard controller would always boot up in OMNI mode, meaning that it would send its own MIDI data and that DP would augment that MIDI input data with that of its own... resulting in double notes.
As with any new version of "anything", perhaps DP preferences need to be reset to accommodate this anomaly? Or that the controller might be reset to OMNI Mode OFF.
Performance Mode will also send multiple MIDI outs simultaneously on many keyboards.
Frodo wrote:All I can add to this is that when it happened to me, I realized that my keyboard controller would always boot up in OMNI mode, meaning that it would send its own MIDI data and that DP would augment that MIDI input data with that of its own... resulting in double notes.
Yeah... I was thinking along these lines when I asked if his keyboard had multiple zones and more than one could be activated and could result in sending duplicate notes when recording MIDI.
To help narrow it down, I would say that he should record some MIDI as he usually does, then immediately look at the Event List for that track and see if the duplicate notes are being created upon recording... which would indicate a setting on the MIDI controller keyboard.
He might also try disconnecting or disabling his qwerty kbd to make sure it isn't sending an opt key. Same for his mousey...
NealF
Post by NealF »
OK. Just got back in the studio. I WASN'T DP!
I must have hit something on the controller kybd. I did a factory reset and all is well.
Yipee! Back to work. Thanks everyone.
MacPro5,1 6-Core Intel Xeon, Processor Speed: 3.46 GHz
Number of Processors: 1
Total Number of Cores: 6
L2 Cache (per Core): 256 KB
L3 Cache: 12 MB
Memory: 32 GB. Mojave. DP 9 and Apogee Duet.
Another satisfied customer! :)
Re: All MIDI notes rec and playback doubled [RESOLVED]
"That darned DP7... everything was working fine and now..." Oops. :D
Thanks for coming back here and letting us know it wasn't a DP issue. A lot of people don't. :( I added "[RESOLVED" to the subject header.
keybored0
Post by keybored0 »
Except a stuck option key would cause zooming to preclude any copying...
newrigel
Post by newrigel »
NealF wrote:OK. Just got back in the studio. I WASN'T DP!
He "ASKED HIS DOCTOR" he he... :mrgreen: :mrgreen:
NealF
Post by NealF »
:D Fell much better now.
L3 Cache: 12 MB
