Well, we did find out a few things. The FW port is good. The Genius at the Apple store hooked up an external HD and it mounted right up. OH YEAH, thanks for the suggestion to take the MOTUs with me, we would have never found out the screwiness without them. As per my signature, I have the 828mkII and the 8Pre. Tried the 828 with my MBP - no go. Emilio (the Genuis) pulled out an earlier MBP (non Unibody), bingo! the 828 mounts up, no prob. We try mine again, no go. So he plugs in the ext HD and installs the FW driver on it. The non unibody mounts the 828 right up. Starts my MBP from the ext HD, (known good system folder, known good driver), no 828. In the meantime I called MOTU Tech support, got through on the first ring (three times yesterday!!!!), talked to Joe, who suggested creating a new user account. Still no 828. Then Emilio brings out a 17" MBP, same configuration as mine, loads the driver, no 828.
So then, I finally figure what the hell? I'll try the 8Pre. Shows right up. We try the 17", the 8Pre shows right up.
So for now it seems there is a hardware conflict between Unibody MacBook Pros and the 828mkII. If I light pipe the 828 into the 8Pre, I can see the 8 ADAT inputs in AudioMidi setup. But, that loses the 2 mic pres on the front of the 828. I like having 18 analog inputs as opposed to 16. Call me greedy.
I do have a techlink open with MOTU, just filled in the tech guy on what went down yesterday, guess I'll have to wait and see what they say it is.
Emilio and I were pretty certain there was something screwy with the driver installation or the driver, but that remains to be seen. We were looking at some of the logs and there were a couple of lines that made me think the FW driver was not being completely installed, but not being a coder, I can't be sure. I'll probably post the pertinent parts of the log to the tech link and see what they think.
WHEW!! And it was only 2 hours at the Apple store to find this much out. Along with the hour drive there and back.
Pappy
