I was encouraged by your Eucon 1.3.0 report recently, but I suppose some OS updates can alter the way it accepts or retains install info or even maintains permissions. That has happened to me with other drivers and plugins in 10.5.6 and earlier. In most cases I just reinstalled whatever was disappearing. In one case a certain developer had to release a fix.stephentayler wrote:I have a problem with Eucontrol 1.3.0, which I had successfully loaded prior to updating from 10.5.6 to 10.5.7 ...... now my MCMix isn't recognised. I don't know if any of you have Eucontrol 1.2.5 working happily??
Otherwise everything seems zippy, especially opening and closing.
Cheers
Stephen
10.5.7 Is Up
Re: 10.5.7 Is Up
- twistedtom
Re: 10.5.7 Is Up
Mickey committed suicide; he got tiered of life!Tim wrote:Let's get Mikey to try it.
I will need to read about it before I try the update, it would be cool if it fixed the MIDI drag and drop problem.
Re: 10.5.7 Is Up
Patch for Euphonix is released: http://euphonix.com/artist/support/downloads.php
v 1.3.1 is ok with 10.5.7
MacBookPro, 10.64, MOTU Ultralite, DP7.2, Live Suite 8, Logic Studio 9, MaxMSP 5
Re: 10.5.7 Is Up
Yes, all is well again in Eucon land!!!
So now everything feels much more responsive.
Warmest regards
Stephen
Warmest regards
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Re: 10.5.7 Is Up
So is this the final update to Leopard? If so, does that mean DP 6.03 is not far behind, with DP 7 coming sometime after the release of Snow Leopard?
iMac 2.66 GHz Intel core 2 duo, 8 gb ram running 10.11.6; 17" Macbook Pro 8,3, 2.5 GHz Core I7, 16 GB ram running 10.13.6; DP 8.07; 8pre-es; 828mkII; 828mkI; microbook II, Behringer ADA8000, Black Lion Auteur 2-Ch. Pre-Amp
Re: 10.5.7 Is Up
Installed 10.5.7 on a partition. I'm having absolutely no problems with it. I'm ready to install on my main drive!
- twistedtom
Re: 10.5.7 Is Up
nick danger wrote:So is this the final update to Leopard? If so, does that mean DP 6.03 is not far behind, with DP 7 coming sometime after the release of Snow Leopard?
Yes DP6.03.1 will be out next week and Dp 7 will be out in the spring.
Re: 10.5.7 Is Up
Apparently Euphonix released 1.3.1 already which fixes the problems with 10.5.7.stephentayler wrote:I have a problem with Eucontrol 1.3.0, which I had successfully loaded prior to updating from 10.5.6 to 10.5.7 ...... now my MCMix isn't recognised. I don't know if any of you have Eucontrol 1.2.5 working happily??
Cheers
Stephen
I just wish I could go back to Leopard at all. If someone could tell me if DP6/PPC/10.5.7 might work with FM7/FM8 or most importantly Kontakt Player 2, I'd appreciate it!
Re: 10.5.7 Is Up
Just tried it, James, and no go on the K2 player. K3 works fine. I do believe the K2 player is probably a dead issue over at MOTU. I'm guessing they might not care as much as the easy fix is using the K3 player. Maybe if they had spare time to look at it, but there is probably a lot more to do in terms of fixing code.James Steele wrote:If someone could tell me if DP6/PPC/10.5.7 might work with FM7/FM8 or most importantly Kontakt Player 2, I'd appreciate it!
I don't have FM7/FM8.
Re: 10.5.7 Is Up
Just want to confirm, is that on a PPC or Intel (your sig says latest mac stuff so seems that it's w/ Intel too, not just PPC)MIDI Life Crisis wrote:Just tried it, James, and no go on the K2 player. K3 works fine. I do believe the K2 player is probably a dead issue over at MOTU. I'm guessing they might not care as much as the easy fix is using the K3 player. Maybe if they had spare time to look at it, but there is probably a lot more to do in terms of fixing code.James Steele wrote:If someone could tell me if DP6/PPC/10.5.7 might work with FM7/FM8 or most importantly Kontakt Player 2, I'd appreciate it!
iMac 3.0 GHz, 8 GHz ram, OS 10.6.4, MOTU 828 Mk II, MOTU MIDI Express-XT (x2), KRK Rokit 6's, Novation Remote Zero SL, Radikal SAC-2k, Triton rack maxed out, Matrix 1000, Handsonic HPD-15 drum pads, tons 'o VI's.....
Re: 10.5.7 Is Up
DP 6.02, all current Mac OS stuff, Dual 2.0 PPC G5, 4GB RAM. MachFive 2, MX4, Kontakt 3, Korg Legacy, GPO, Finale
Re: 10.5.7 Is Up
Re: 10.5.7 Is Up
I'd like to miss it in place of a new machine, but alas, other priorities prevail...dbender wrote: thanks...missed that.....thanks
Re: 10.5.7 Is Up
Is your G5 the April / May 2005 model with the PCI bus ?(not PCI-x, etc.) Looks a lot like my setup but I've stayed at 10.4.11 because Waves 4 wouldn't work on 10.5. I've WUP'd to 6, so if Korg, GPO, UAD works ... I can catch upMIDI Life Crisis wrote: My sig:
Re: 10.5.7 Is Up
How can I tell? I won it from Macworld so didn't make an 'informed' decision.bayswater wrote:Is your G5 the April / May 2005 model with the PCI bus ?(not PCI-x, etc.) Looks a lot like my setup but I've stayed at 10.4.11 because Waves 4 wouldn't work on 10.5. I've WUP'd to 6, so if Korg, GPO, UAD works ... I can catch upMIDI Life Crisis wrote: My sig:
