audio MIDI setup in Leopard crashes
A.M.S. comes up fine on my dual core intel mac OS 10.5.5. It shows my MTP AV.
I can add a MIDI device but if I try to edit it, AMS crashes. I trashed its preference. Loaded the driver 1.37 for my MTP AV. Got rid of all other MIDI drivers. Any other ideas??
thanks,
scooter
thanks,
scooter
Macbook Pro OS 10.12.6, 2.6 GHz Intel Core i7, 16 gig memory, Apollo Twin audio interface.
- kassonica
Re: audio MIDI setup in Leopard crashes
Did you repair permissions after installing driver?
If not I try it and see if it helps.
Try making a new AMS from scratch.
It's been well over a year since I've attempted this.
I can't get my AMS to work In OS 10.5.6. The screen comes up fine with my 2 microlites and the MTP AV all showing up fine.
As soon as I try to add or edit a MIDI device in any way, it crashes.
I've installed MOTU USB OSX Install v.1.3.7, I took out all MIDI drivers from my Library/Audio/ MIDI Drivers except for the Motu MIDI Driver.plugin
The only thing I can think of is uninstalling USB OSX 1.3.7 and reinstalling, but there is no uninstall option on the install.
Does any one know how best to do that? I can at least start there.
thanks,
scooter
thanks,
scooter
Sorry, I meant to move this post to the General Macintosh category. But i don't know how to do that.
scooter
scooter
I had that happen in 10.5.5 on my Mac Pro. I tried everything I could think of with no success. Finally a re-install of OS X solved the problem. I never did figure out what was corrupted.
Wow! Thanks Phil. I guess if worse comes to worse I could go there but I really hope I don't have to.
scooter
scooter
If you figure it out, let us know.
I'm working on it. I'll definitely figure it out at some point and I'll report back when I do.
scooter
scooter
I've been working on the same problem and so far I have found that on my system, PT8 installs some Digi MIDI drivers that are wreckin havoc with AMS. When I delete them, and re-install the Motu usb driver, everything returns to (?)normal(?), but PT8 refuses to start up. Then, when I re-install the PT audio, and MIDI drivers
I can't get DP6.01 to run. I am really
and
ed. Of course since I've been working on it for about 16 hrs I'm going
crazy!!!!!! Need help and fast!!!! Lucky my next projects don't depend on MIDI so I'm safe for a while. As a matter of fact I think I'll try to disconnect my MIDI express and see what happens. I had no problems on my MBP, and Mbox mini. The only thing I can guess is that when I tested it, there was no MIDI interface connected. I'm going to test it again, and make sure.
DP, ProTools,Reason,Mashine, Mac 6core 2013, 4core MacBook Pro, Waves, Slate VMS ONE, McDsp, Softube etc.. Avid S3, Yamaha 01V96i, Digi 003, and a whole lot of 'the next best thing' analog gear, slowly exiting the workspace!!
Oh well, no matter what I do, I can't get DP6, and PT8 to work together on my Macpro. Both programs take forever to start up. They do start up, but only after saying 'not responding' in the force quit window. But if you wait, they will open up. It is strange because the same set up on my macbook pro opens up right away. AMS opens right away on MBP, but stalls on my Macpro. It's 6 a.m. and I am burnt. I hope somebody can find a solution.
Check console...sacknell wrote:Oh well, no matter what I do, I can't get DP6, and PT8 to work together on my Macpro. Both programs take forever to start up. They do start up, but only after saying 'not responding' in the force quit window. But if you wait, they will open up. It is strange because the same set up on my macbook pro opens up right away. AMS opens right away on MBP, but stalls on my Macpro. It's 6 a.m. and I am burnt. I hope somebody can find a solution.
There are probably some trace of what's going on there.
/B
The only console I can almost understand is an old analog rec console. When I tried the console, terminal, etc..... I was and still am cluelessbjornln wrote:Check console...
/B
I'm going to re-install DP5 and PT7 on my macpro since I have(HAD) a free weekend. Everything was great until I started using PT8 and DP6 together..... let's see if Utopia still exists...... hope I ain't gotta install OSX again.....
Well, I'm doing the dreaded archive and install right now, so I'll let you know what happens.
scooter
scooter
The install and archive did not fix the problem.
It took a full re-install of Leopard to fix the problem. It's fine now and only God knows what was going on with my AMS.
scooter
scooter
