audio MIDI setup in Leopard crashes
scooter
Post by scooter »
A.M.S. comes up fine on my dual core intel mac OS 10.5.5. It shows my MTP AV.
I can add a MIDI device but if I try to edit it, AMS crashes. I trashed its preference. Loaded the driver 1.37 for my MTP AV. Got rid of all other MIDI drivers. Any other ideas??
thanks,
scooter
Macbook Pro OS 10.12.6, 2.6 GHz Intel Core i7, 16 gig memory, Apollo Twin audio interface.
kassonica
Re: audio MIDI setup in Leopard crashes
Post by kassonica »
Did you repair permissions after installing driver?
If not I try it and see if it helps.
Frodo
Post by Frodo »
Try making a new AMS from scratch.
scooter
Post by scooter »
It's been well over a year since I've attempted this.
I can't get my AMS to work In OS 10.5.6. The screen comes up fine with my 2 microlites and the MTP AV all showing up fine.
As soon as I try to add or edit a MIDI device in any way, it crashes.
I've installed MOTU USB OSX Install v.1.3.7, I took out all MIDI drivers from my Library/Audio/ MIDI Drivers except for the Motu MIDI Driver.plugin
The only thing I can think of is uninstalling USB OSX 1.3.7 and reinstalling, but there is no uninstall option on the install.
Does any one know how best to do that? I can at least start there.
thanks,
scooter
scooter
Post by scooter »
Sorry, I meant to move this post to the General Macintosh category. But i don't know how to do that.
scooter
Phil O
Post by Phil O »
I had that happen in 10.5.5 on my Mac Pro. I tried everything I could think of with no success. Finally a re-install of OS X solved the problem. I never did figure out what was corrupted.
scooter
Post by scooter »
Wow! Thanks Phil. I guess if worse comes to worse I could go there but I really hope I don't have to.
scooter
Phil O
Post by Phil O »
If you figure it out, let us know.
scooter
Post by scooter »
I'm working on it. I'll definitely figure it out at some point and I'll report back when I do.
scooter
sacknell
Post by sacknell »
I've been working on the same problem and so far I have found that on my system, PT8 installs some Digi MIDI drivers that are wreckin havoc with AMS. When I delete them, and re-install the Motu usb driver, everything returns to (?)normal(?), but PT8 refuses to start up. Then, when I re-install the PT audio, and MIDI drivers :( I can't get DP6.01 to run. I am really :?: and :shock: ed. Of course since I've been working on it for about 16 hrs I'm going :lol: crazy!!!!!! Need help and fast!!!! Lucky my next projects don't depend on MIDI so I'm safe for a while. As a matter of fact I think I'll try to disconnect my MIDI express and see what happens. I had no problems on my MBP, and Mbox mini. The only thing I can guess is that when I tested it, there was no MIDI interface connected. I'm going to test it again, and make sure.
DP, ProTools,Reason,Mashine, Mac 6core 2013, 4core MacBook Pro, Waves, Slate VMS ONE, McDsp, Softube etc.. Avid S3, Yamaha 01V96i, Digi 003, and a whole lot of 'the next best thing' analog gear, slowly exiting the workspace!!
sacknell
Post by sacknell »
Oh well, no matter what I do, I can't get DP6, and PT8 to work together on my Macpro. Both programs take forever to start up. They do start up, but only after saying 'not responding' in the force quit window. But if you wait, they will open up. It is strange because the same set up on my macbook pro opens up right away. AMS opens right away on MBP, but stalls on my Macpro. It's 6 a.m. and I am burnt. I hope somebody can find a solution.
bjornln
Post by bjornln »
sacknell wrote:Oh well, no matter what I do, I can't get DP6, and PT8 to work together on my Macpro. Both programs take forever to start up. They do start up, but only after saying 'not responding' in the force quit window. But if you wait, they will open up. It is strange because the same set up on my macbook pro opens up right away. AMS opens right away on MBP, but stalls on my Macpro. It's 6 a.m. and I am burnt. I hope somebody can find a solution.
Check console...
There are probably some trace of what's going on there.
/B
sacknell
Post by sacknell »
bjornln wrote:Check console...
/B
The only console I can almost understand is an old analog rec console. When I tried the console, terminal, etc..... I was and still am clueless :oops: But I did find out that the digi drivers and the Motu usb drivers are conflicting. I remembered that my wife's G5 had PT7 only. So I installed DP6 on it. Everything worked flawlessly until I installed the usb drivers. Everything went haywire! When I trashed the motu driver, back to normal. Motu will run on the digidesign drivers, but DD isn't playing fair. This is a big issue because I use Express XT, and DTP for my DP6- Tascam sync. I hope it hasn't come to the point of having to use a separate OS for each program. I really enjoyed(at least til now) the freedom of being able to switch between the two without having to re-start like OS9........
I'm going to re-install DP5 and PT7 on my macpro since I have(HAD) a free weekend. Everything was great until I started using PT8 and DP6 together..... let's see if Utopia still exists...... hope I ain't gotta install OSX again.....
scooter
Post by scooter »
Well, I'm doing the dreaded archive and install right now, so I'll let you know what happens.
scooter
scooter
Post by scooter »
The install and archive did not fix the problem.
It took a full re-install of Leopard to fix the problem. It's fine now and only God knows what was going on with my AMS.
scooter
