Quick survey: How do you power your Traveller?
Let's say you have a Traveller connected to your desktop.
You don't take it on remotes, you just use it in that one location (home or whatever).
Do you just use BUS power or do you use the wart?
- Dwetmaster
I would definitely plug it in wherever and whenever it's possible.
- Dwetmaster
BTW when I said plug it in, I ment plug it into a AC outlet of course
- Dwetmaster
Any specific reason for that?lavrell wrote:I'm using the buspower fron my MacBook even when i have the chance to plug it in the wall.
- rockitcity
I always use the wall-wart. I figure it will provide more stable power than the bus power (I don't ever plug anything else into the firewire loop-through port anyway). I often bus-power portable firewire drives, but they are plugged into my cardbus adapter (which also has a power supply attached).
The downside of all this stuff (20" external monitor, keyboard, trackball, USB hub, etc.) attached to the Powerbook is that it makes it a hassle to move it, so it tends to just be an underpowered desktop computer. Probably will replace it later this year with an Intel imac, but I'm kind of waiting for the next generation to come out before upgrading.
Bob
Bob
Mac Mini Quad i7 2.6 Ghz, 16 G RAM, 2 SSD's. Motu 896 HD Hybrid, 8pre, Fastlane USB, Presonus Faderport, vintage guitars!
- DeafMute
Funny, I don't even recall where my AC adaptor for the Traveler is.
I keep relying on my Firewire to power it.
Hmm, maybe i'll think twice on my next recording session...
PePe.
Flash Focus Record.
Mac Book Pro 2.16 Ghz - 2GB RAM. OS 10.5.7
Black Lion modded Projectmix. MOTU Traveler
Digital Performer 5.13
Wurlitzer 200 Piano
DeArmond Archtop X-155 Guitar
Flash Focus Record.
Wurlitzer 200 Piano
I only use the bus. I've never even upacked the wart. The power in my house is dirty, and I think the electricity coming from the macbook is cleaner (even when the macbook is plugged in, but I haven't measured). Normally, I track with just the macbook battery as the only power source, so that I can remove the variable of the dirty wall power.
