Quick survey: How do you power your Traveller?
Ebaange
Post by Ebaange »
Let's say you have a Traveller connected to your desktop.
You don't take it on remotes, you just use it in that one location (home or whatever).
Do you just use BUS power or do you use the wart?
Bus always, I've never had a single problem, but I have heard that some Firewire ports do not provide enough juice to adequately power the Traveler. I have enough warts. Why add another?
Dwetmaster
Post by Dwetmaster »
I would definitely plug it in wherever and whenever it's possible.
lavrell
Post by lavrell »
I'm using the buspower fron my MacBook even when i have the chance to plug it in the wall.
Dwetmaster
BTW when I said plug it in, I ment plug it into a AC outlet of course 8)
Dwetmaster
lavrell wrote:I'm using the buspower fron my MacBook even when i have the chance to plug it in the wall.
Any specific reason for that?
rockitcity
Post by rockitcity »
I always use the wall-wart. I figure it will provide more stable power than the bus power (I don't ever plug anything else into the firewire loop-through port anyway). I often bus-power portable firewire drives, but they are plugged into my cardbus adapter (which also has a power supply attached).
The downside of all this stuff (20" external monitor, keyboard, trackball, USB hub, etc.) attached to the Powerbook is that it makes it a hassle to move it, so it tends to just be an underpowered desktop computer. Probably will replace it later this year with an Intel imac, but I'm kind of waiting for the next generation to come out before upgrading.
Bob
Mac Mini Quad i7 2.6 Ghz, 16 G RAM, 2 SSD's. Motu 896 HD Hybrid, 8pre, Fastlane USB, Presonus Faderport, vintage guitars!
mshelsy
The Wall
Post by mshelsy »
The Wall
DeafMute
Post by DeafMute »
Funny, I don't even recall where my AC adaptor for the Traveler is.
I keep relying on my Firewire to power it.
Hmm, maybe i'll think twice on my next recording session...
PePe.
Flash Focus Record.
Mac Book Pro 2.16 Ghz - 2GB RAM. OS 10.5.7
Black Lion modded Projectmix. MOTU Traveler
Digital Performer 5.13
Wurlitzer 200 Piano
DeArmond Archtop X-155 Guitar
antichef
Post by antichef »
I only use the bus. I've never even upacked the wart. The power in my house is dirty, and I think the electricity coming from the macbook is cleaner (even when the macbook is plugged in, but I haven't measured). Normally, I track with just the macbook battery as the only power source, so that I can remove the variable of the dirty wall power.
antichef wrote: Normally, I track with just the macbook battery as the only power source, so that I can remove the variable of the dirty wall power.
Wow. How much battery life do you get? That would last me about 10 minutes.
gregwhartley
Post by gregwhartley »
Bus, no problems here.
"We are all disgusting, doomed to our dirty little tasks. Eating and farting and scratching and smiling and celebrating holidays." -Bukowski
Bwanasonic
Post by Bwanasonic »
Always Bus, but I have recently started using a powered Firewire hub in my home setup.
Kerry M
