Any 5.12 problems (Allegedly)
If you have a problem other then registration with 5.12 please start posting it here...
Clippings are not working properly in retaining always run in realtime setting...
waxman
- Dwetmaster
Re: Known 5.12 bugs
They're not??? Can you be more specific?waxman wrote:Clippings are not working...
Hey, not to be the Unicornation police, but --
Can we change the title of this thread until these "bugs" are confirmed or at least substantiated by a sizeable number of user claims?
I'm not against posting a bug list. I'm just saying let's build up to it by gathering some substance first.
Things can take an unnecessarily alarmist turn otherwise.
Cool?
Cool?
- emulatorloo
Agreed -- it is very easy for "conventional wisdom" to be set by thread titles.chrispick wrote:I'm not against posting a bug list. I'm just saying let's build up to it but gathering some substance first.
Before you know it posts will almost automatically begin with "EVERYBODY KNOWS THAT DP 5.12 IS TOO BUGGY"
- Dwetmaster
That's why I jumped to ask for more precision
Possible 5.12 problems (alledgedly)
LOL
If that doesn't cover it...
Here is the workaround for clippings... When you use a clippings window with multiple plugs you need to open the plug after dragging it to the insert and put it in "always run in real time"
Some times clippings sets that up other times not. Even if the clipping you saved has that setting it does not always come back...
waxman
I think Chrispick nailed it.
Let's give it a chance first.
My guess is it's mostly a "stability"/bug-zapping update, so I'd like to think MOTU's kicked a few goals here.
I s'pose it's easy to be brave and patient when the app's still being downloaded...
Ok how is DP 5.12 working for everyone it has been a week...
waxman
As I mentioned in the thread I started 'audio files not playing back in DP 5.12', I opened a 5.11 file in 5.12 and four mono audio tracks (out of over two dozen) wouldn't play back. Eventually, I found that if I did 'Merge soundbites', the new soundbite would play back. But this was enough to scare me away from using 5.12 for a while.
http://www.motunation.com/forum/viewtopic.php?t=20240
Bob
DP 11.23
Metric Halo ULN-8 mk4
DP 11.23
So is it ok to upgrade yet from 5.11?
Macbook pro, 3 gigs of ram, osx 10.62, Dp 5.13, Live 8.1.2, Reason 4, Tc powercore Virus, Albino 3.02, proper ergonomic sitting posture, plenty of coffee (french press only with a pinch of cardamon added)
My dp inspired music.....
http://www.myspace.com/aislingbeing" onclick="window.open(this.href);return false;
http://www.myspace.com/wigginsmaroo" onclick="window.open(this.href);return false;
http://www.mp3.com.au/artist.asp?id=10004" onclick="window.open(this.href);return false;
Yeah, Josh, now would be a good time to know; it's almost in my grubby little feet...
Download nearing completion...
there seems to be a lot of frenzy about bugs and such, I wanted to check in before I install....but I'm still annoyed that powercore is still not UBmonkey man wrote:Yeah, Josh, now would be a good time to know; it's almost in my grubby little feet...
- richardein
so far no problems here, with MIDI, usb, or audio, on a powerbook or on a dual gig g5. kontakt works, ditto altiverb 5, ditto mach five, the main plugs I'm using right now.
Richard Einhorn
MacBook Pro 2019, Motu M4, EWQLSO Play Platinum Plus, Ivory, Kontakt 5, Izotope Ozone, Izotope RX, Omnisphere other plug-ins, instruments, etc. that are used less often. StudioLogic SL88 Grand
