Anyone use an Arturia KeyLa MK2 88 ?
kolandscapes
Post by kolandscapes »
And if so ... how is MIDI set up ?
I'll admit up front, I'm something of a neophyte concerning MIDI since most of my recording experience has been done with audio going straight into the system .. And i recently got the MK2 to take advantage of Arturia's Inst. suite. But I can't figure out how to set it up where One Ch controls One virtual Inst. ONLY ?
They are all sounding together under a single key press even though I have each assigned to a separate MIDI ch ?
I did speak with MOTU support online and they seem to think it's set up correctly ? I'm at a bit of a loss here ?!?
Suggestions appreciated :-)
Screenshot 2024-08-11 at 5.11.09 PM-1.jpg (310.08 KiB) Viewed 2787 times
If You Can't Hear It .. Don't Go Near It !!
Re: Anyone use an Arturia KeyLa MK2 88 ?
Do you have Studio>Multi Record on?
kolandscapes
It is checked .. I'm assuming that means it is "On" ?
Screenshot 2024-08-12 at 3.37.04 AM.png (87.78 KiB) Viewed 2779 times
ng62gn
Post by ng62gn »
Make sure your inst. is correctly configured in Audio MIDI Setup (DP Setup menu or Mac Utilities folder)
This is just a note to say that this is an easy problem to fix. Don't worry, we'll get you sorted.
kolandscapes
ng62gn wrote: Mon Aug 12, 2024 2:09 am Make sure your inst. is correctly configured in Audio MIDI Setup (DP Setup menu or Mac Utilities folder)
Running on a Studio M2Max ..
They're all seen ? If I'm not mistaken all the connection happens through USB .. unlike back in the day when you had to pull the connectors to the MTP unit ?
Screenshot 2024-08-12 at 1.03.00 PM.png (300.32 KiB) Viewed 2713 times
I'm curious about the appearance of the "DAW" version of your keyboard. It shouldn't matter since you're in Multi and can choose the source, but perhaps there's something about multiple iterations of that device that CoreMIDI can't parse.
kolandscapes
stubbsonic wrote: Mon Aug 12, 2024 9:38 am This is just a note to say that this is an easy problem to fix. Don't worry, we'll get you sorted.
I would think ... outside my MIDI idiocy :lol:
Appreciate the note of confidence as it's really holding me up :)
kolandscapes
stubbsonic wrote: Mon Aug 12, 2024 10:45 am I'm curious about the appearance of the "DAW" version of your keyboard. It shouldn't matter since you're in Multi and can choose the source, but perhaps there's something about multiple iterations of that device that CoreMIDI can't parse.
Not quite sure what you mean ? .. The MK2 Updater image ?
Can't imagine DP/CoreMIDI would be confused as the Keylab is by no means an oddball controller ?
I'm just wondering why you are using MIDI Multi Record. I always run DP with MIDI Multi record OFF and Audio Multi Record ON.
Unless you want to record multiple performances to multiple VIs simultaneously, I'd just turn MIDI Multi Record off. That way, any and all connected MIDI Controllers will address the current record-enabled VI. You don't have to specify the MIDI Input Source. You can use the Mod Wheel on one keyboard while playing notes on another and manipulating an Expression Pedal connected to a third; all will impact the record-enabled VI.
With this approach, make sure MIDI Controllers are not spitting out notes on multiple MIDI channels; if so you will get doubled MIDI recordings. And working the Mod Wheel on two keyboards at once will give weird, jumpy results!
HC Markus
https://rbohemia.com
Yes, turn MIDI Multi Record OFF, and don't leave home without this.
Or even this. Desktop version here.
Oh, and are you connected by USB, or MIDI cables? I could never get my KL88mkII to work properly via MIDI. USB is the way to go.
I think the reason multi was suggested was to troubleshoot the original issue of VI's "all sounding together"
In the image showing the available sources, we see three versions of the KeyLab MkII: DAW, MIDI, and Updater (missing). However, it shows ALL of them under the heading "UNCONFIGURED PORTS".
So that might be a good first step, to go into Audio MIDI Setup (AMS) and double-click device KeyLab MkII. Then in the edit window that opens, switch PROPERTIES to the PORTS tab. It looks like it would (should?) have two ports, one called MIDI, and one called DAW. I'm guessing the MIDI where the KeyLab's 5-pins in/out are treated like a separate port on the same device. And that DAW is the USB feeding the DAW (in). Not sure what the output of DAW does.
In the image showing Audio MIDI Setup, we see the DAW & Updater. I'm tempted to tell you to delete updater, as that just seems like some leftover something. Worst case, if it is needed, you could re-install drivers. The New External Device shows as missing. Do you know what that is? If you don't need it, you can probably get rid of it. Just adding an unnecessary item to the list.
CharlzS
Post by CharlzS »
On some of the Arturia keyboards, DAW ports allow you to configure the transport controls as a control surface and the MIDI ports function normally as notes, CCs, etc.
DP 11.34 PT 2025.6 Mixbus 11 VEP 7.x with various VIs
MOTU M4 on MacBook Air M2 2023 Sequoia.5
kolandscapes
HCMarkus wrote: Mon Aug 12, 2024 11:53 am I'm just wondering why you are using MIDI Multi Record. I always run DP with MIDI Multi record OFF and Audio Multi Record ON.
It was checked. I think either MOTU or Sweetwater activated that . Can't remember why. I unchecked it and am now able to record a MIDI inst while listening to another MIDI inst. YAY !!
Most appreciated for the input from all here :)
kolandscapes
cuttime wrote: Mon Aug 12, 2024 12:39 pm Yes, turn MIDI Multi Record OFF, and don't leave home without this.
Connected via USB ...
By the way, I went to the page you referenced for the App. Looks great but I can't find the Download link for the Desktop version on the link ?!?
