DP 11.32: Anybody else notice the track selector is broken in the Mixing Board view--?
greg328
Post by greg328 »
I'm noticing since I updated to DP 11.32-I'm no longer able to show/hide the track selector on the Mixing Board. I also am noticing that the display of the mixing board is glitchy and sometimes shows weird anomalies like black meter columns in random locations.
Could this be a new bug? Would love confirmation from others--and I'll report it to MOTU--
Maybe a re-install of 11.32 is in order?
Many thanks,
Greg
PS--an observation--when the Mixing Board is separated from the main window (how I usually situate it), clicking "show/hide track selector" in the bottom left does nothing. When it occupies the bottom of the track window--not separated, click show/hide track selector brings up ONE channel strip on the far left of the main window. Not normal behavior!
Re: DP 11.32: Anybody else notice the track selector is broken in the Mixing Board view--?
I've noticed that the icon in the lower left corner of the mixer window is a tiny and indecipherable area. The track selector is a tiny little click field that I must click blindly until I luck into it. It's there, but it is barely separated from the field that resizes the window.
Screenshot 2024-07-09 at 10.49.52 AM.png (20.91 KiB) Viewed 4341 times
greg328
Post by greg328 »
Yep, that’s the button. Mine has always been easily seen and clicked-I have a different theme than yours-but now clicking it does nothing-
Ah. Thanks, I think I will change my theme.
That's got to be a bug. Is it the same for all projects?
Definitely send MOTU a support request.
greg328
Post by greg328 »
New Finding:
turns out-like SS, I was not clicking accurately enough. Seems like the 11.32 update made this button respond a bit differently to past versions. You have to click on the "right-side" portion of the show/hide button. Very sensitive to cursor location. If you just click in the center of that button, you get nothing!
So--I guess no support ticket needed--just more careful clicking!
Greg
File this under "DP has some tiny GUI elements."
I think you're right that this is a fairly recent change. I doubt they deliberately said, "That track selector button is way too big, let's shrink it down and make it more of a game of chance. It'll be fun."
I do think it warrants sending either a support request or just a feedback note.
Ive noticed the odd thing that doesn't work well with some themes. I use Beyond-Black 2.4 with a few custom tweaks, made by a member here. The track selector button is quite apparent and works fine. If the theme being used is MOTU supplied, then a support is warranted.
Screen Shot 2024-07-10 at 12.27.27 PM.png (17.81 KiB) Viewed 4197 times
greg328
Post by greg328 »
Is there a way to share that Beyond Black theme here? I’d like to try it-
Greg
greg328 wrote: Thu Jul 11, 2024 3:47 am Is there a way to share that Beyond Black theme here? I’d like to try it-
Greg
Should be searchable here at motunation. That’s where I got it. Rick Cornish did it. Using the Google search you can find V2.3. If RIck sees this he might tell us where V2.4 is.
greg328
Post by greg328 »
Thank u
Phil O
Post by Phil O »
Yep, I've noticed this for some time. I've started using command-shift-T because the sweet spot on that tiny icon is just too hard to find.
primeevolutionary
Post by primeevolutionary »
I'm not sure if this is a custom command I created, or, a regular command, but, I hate tiny mouse functions. I use option+command+E to access the track selector. This works on Tracks, Sequence Editor and Mixing Board.
Last edited by primeevolutionary on Thu Jul 11, 2024 7:20 pm, edited 2 times in total.
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
Phil O wrote: Thu Jul 11, 2024 8:09 am Yep, I've noticed this for some time. I've started using command-shift-T because the sweet spot on that tiny icon is just too hard to find.
I wouldn’t have thought that the size of the image in a theme has any effect on the clickable area. That doesn’t make much sense when you look at the package contents. But, remember when we were all complaining about the size of the velocity symbols when editing MIDI? Editing those images making them big and bright fixed that problem.
Yeah... I've reported this to MOTU. The show/hide track selector button is competing with re-size function. It's a real PITA. I made a soft key on Avid Control on my iPad for the show/hide hotkey because of this.
corbo-billy
Post by corbo-billy »
viewtopic.php?t=72310
Imac M4 24" under Sequoia 15.3.1 & Kontakt 8.2. _ Fireface800 X 2 _ FilterBank2 Sherman & Gibson Explorer Pro _ Virus C Desktop _ Adrenalinn III & Voyager Moog _ SpeakerPhone 2 _ PolyEvolver Keyboard _ Tempest _ D.P. 11.34 _
