Hi all, I'm anew member to the forum although a VERY long time user of Performer.
This is an odd setup so please bear with me, any help would be appreciated.
Computer #1 imac 10.5.8 DP6 micro express interface. works normally when MIDI cable 6 is going to sound module, but I'm trying to dump old band tracks from COMP 1 to computer 2 because the individual sequences won't load into DP9 on computer 2:
imac 10.6 DP 9 using the MIDI in of my NI Komplete Audio 6 IF. The MIDI notes trigger my virtual piano plug-in (XLN addictive keys) BUT the sustain pedal data does NOT go through.
SO: MIDI out from micro express to MIDI IN of NI Komplete audio 6 IF no controller 64 goes through.
Does DP9 have a filter of some sort blocking that data stream?
TIA
Jeff
Controller 64 not passing though
Re: Controller 64 not passing though
Jeff
Thanks so much for the tip. I will check that when I get home tomorrow afternoon.
Jeff
Jeff
Yep that was it.
