Spontaneous restart
Spontaneous restart
My computer spontaneously shut down and restarted three times yesterday, and once a couple of months ago, but so far not today...yet.
Wha...? If that ever happened before it's been years and I dont remember it. I have a "report" that was generated after the restart, but I dont have a clue what it means. I wont put it here since it's quite long, but if any of my really, really, really clever people here wouldnt mind looking at it and telling me what they think might have happened, I'd appreciate it (private message of some kind?). Would like to avoid a possible calamity in the (possibly near) future.
Mac mini M1, 14.3.1, 16gigs RAM, 828 mk3 Hybrid, DP 11.23, Various VIs
- FMiguelez
Re: Spontaneous restart
That reminds me of my old PCs...
It sounds like a bad stick of RAM to me. Let's see what Mike Halloran says about it.
Spontaneous restart
Wha...? If that ever happened before it's been years and I dont remember it. I have a "report" that was generated after the restart, but I dont have a clue what it means. I wont put it here since it's quite long, but if any of the really, really, really clever people here wouldnt mind looking at it and telling me what they think might have happened, I'd appreciate it (private message of some kind?). Would like to avoid a possible calamity in the (possibly near) future.
Step one is to confirm or eliminate a hardware problem. How long since you've changed the battery and cleaned the heatsink vents?
The NV RAM battery should be changed every 5 years or so. The OE is a BR2032 but the standard CR2032 is fine in these and lasts just as long. Believe it or not, having no battery is better than a low one (your settings wouldn't be saved, however). If you can't remember when, change it.
The heatsink vents are known to clog with dust on these causing a thermal shutdown. You won't see this without looking at the side.
Have you verified that the power cord and any power strip etc. is good and snug? It happens...
Yes, there are potential software issues but let's start with the basics.
- ronjams
You are headed for a complete breakdown of the machine immediately get the computer cleaned. Dust is the culprit. If you can’t get it to a shop, take action and get a vacuum along with some type of artist brush to get the dirt out make sure you clean the video card and from now on put the computer in a well vented areagavspen wrote:My computer spontaneously shut down and restarted three times yesterday, and once a couple of months ago, but so far not today...yet.
Wha...? :? If that ever happened before it's been years and I dont remember it. I have a "report" that was generated after the restart, but I dont have a clue what it means. I wont put it here since it's quite long, but if any of the really, really, really clever people here wouldnt mind looking at it and telling me what they think might have happened, I'd appreciate it (private message of some kind?). Would like to avoid a possible calamity in the (possibly near) future. :cry:
Mac Studio M1 Max DIGITAL PERFORMER• 1248/8pre ES • Falcon/kontakt/Unify & A LOT MORE GEAR
This was double posted. I'll merge topics.
Did I double post James? Sorry.
Battery changed within living memory but the thing hasnt been cleaned...ever! I'll try that. There must be quite a bit of filth in there!
FMiguelez wrote:That reminds me of my old PCs...
Just saw this. That's another possibility.
Although TechTool Pro is my go-to RAM tester, there are other ways to suss it out.
If you purchased AppleCare and still have the DVD, you received a copy of TechTool Deluxe. This can be updated to the version that runs on Lion for free. It was discontinued when OS 10.8x was released.
https://www.micromat.com/techtool-delux ... -available
I had this problem for 18 months. Things I tried were
- removing startup apps
- booting up in safe mode
- unplugging every peripheral and adding them back one by one
- used built in audio instead of MOTU PCI
- reset PSU (and changed power cable)
- reset PRAM
- tested every stick of RAM multiple times in multiple slots
- Apple Hardware Test
- cleaned all dust out of computer
- rebuilt boot HD
- googled a zillion articles on my issue.
Nothing worked
Finally I got it checked by a local Mac tech who thought it may have been the logic board, he swapped a known good one in, and it ran fine. So my logic board was farkakte, ordered a replacement from eBay, he put it in, my Mac is now back to being awesome.
- reset PRAM
- rebuilt boot HD
Nothing worked
Well I sure hope it aint the logic board. Isnt it time to get a new computer when that goes? Isnt that an expensive fix?
Anyway, I opened it up and cleaned it as best I could. There *might* have been a little dust in there...haha. Took everything out I could....drives, cards, ram....and vacuumed eeeeever so gently. Cleaned up the heat sink as much as possible but it's a bit hard to get to, on this model anyway. It's a ten year old box...yoikes!...and it's not spotless, but back to the level of dust that might have been in it, oh, say 6-7 years ago.
Much to my surprise, when I put it all back together it started up fine. I was sure I was going knock something off it's perch in there.
The battery in less than 5 years old and it's in a reasonably well ventilated spot.
The start ups have been intermitent...of course; the hardest problems to fix...none for a few days, one today (before clean up), so we'll see going forward. Ram check if it happens again, I guess.
Thanks for the advice.
Let us know. Threads like these help others.
Will do Mike.mikehalloran wrote:Let us know. Threads like these help others.
Well, I was going to wait a month to report back, just to be sure the cleaning had worked, and I almost made it. Just had the same spontaneous restart problem. Rats!!
I hesitate to include this since it's so long, but there are many clever people here who might know what it means. This is the report I got.
Thanks,
Gavin
Anonymous UUID: 938255E5-5AF3-FBB1-0668-2D7B94FD4971
Mon Sep 24 17:26:00 2018
panic(cpu 0 caller 0xffffff7f91a71084): "Uncorrectable Fbd memory error detected. FERR_NF = 0x20000020 , NERR_NF == 0x02000021\n"@/SourceCache/AppleMCEDriver/AppleMCEDriver-119.4.0/AppleMCEDriver.cpp:947
Backtrace (CPU 0), Frame : Return Address
0xffffff804b086cb0 : 0xffffff8010023139
0xffffff804b086d30 : 0xffffff7f91a71084
0xffffff804b086da0 : 0xffffff7f91a703c6
0xffffff804b086df0 : 0xffffff7f91de3498
0xffffff804b086e30 : 0xffffff7f91de3030
0xffffff804b086e40 : 0xffffff7f91ded4ba
0xffffff804b086e60 : 0xffffff7f91ded3b1
0xffffff804b086eb0 : 0xffffff7f91def819
0xffffff804b086ed0 : 0xffffff80104caeb9
0xffffff804b086f10 : 0xffffff7f91da9b21
0xffffff804b086f50 : 0xffffff7f91ddaead
0xffffff804b086f60 : 0xffffff7f91de250b
0xffffff804b086f80 : 0xffffff80100dc06b
0xffffff804b086fd0 : 0xffffff80100f4649
0xffffff8071ac3f50 : 0xffffff80100378fa
0xffffff8071ac3f90 : 0xffffff8010037c48
0xffffff8071ac3fb0 : 0xffffff80100d7c67
Kernel Extensions in backtrace:
com.apple.driver.AppleACPIPlatform(1.7)[D49DC2E0-97DF-32E6-A8ED-7A12EF1AA51B]@0xffffff7f91dd4000->0xffffff7f91e2bfff
dependency: com.apple.iokit.IOACPIFamily(1.4)[A35915E8-C1B0-3C0F-81DF-5515BC9002FC]@0xffffff7f910a5000
dependency: com.apple.iokit.IOPCIFamily(2.7.3)[1D668879-BEF8-3C58-ABFE-FAC6B3E9A292]@0xffffff7f906c1000
com.apple.driver.AppleAPIC(1.6)[9DEBAEBC-8619-3510-8C36-663CE50BA9E2]@0xffffff7f91da8000->0xffffff7f91daafff
com.apple.driver.AppleMCEDriver(1.1.9)[95CF919D-57C6-3336-B7D4-14D44861E4B0]@0xffffff7f91a6f000->0xffffff7f91a73fff
BSD process name corresponding to current thread: kernel_task
Mac OS version:
13F1911
Kernel version:
Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64
Kernel UUID: 8926E512-6714-34FC-B27C-6AE90EB51D5E
Kernel slide: 0x000000000fe00000
Kernel text base: 0xffffff8010000000
System model name: MacPro3,1 (Mac-F42C88C8)
System uptime in nanoseconds: 343824893236
last loaded kext at 246329925808: com.apple.filesystems.msdosfs 1.9 (addr 0xffffff7f92238000, size 65536)
last unloaded kext at 307089929333: com.apple.filesystems.msdosfs 1.9 (addr 0xffffff7f92238000, size 57344)
loaded kexts:
com.paceap.kext.pacesupport.snowleopard 5.9.1
com.uaudio.driver.UAFWAudio 4.1.1 16344
com.motu.driver.FireWireAudio 1.6 73220
com.uaudio.driver.UAD2System 7.3.0
com.tcelectronic.powercore 4.3.1f34
com.apple.filesystems.autofs 3.0
com.apple.iokit.IOBluetoothSerialManager 4.2.7f5
com.apple.driver.AppleHWSensor 1.9.5d0
com.apple.iokit.CSRBluetoothHostControllerUSBTransport 4.2.7f5
com.apple.driver.AudioAUUC 1.60
com.apple.driver.AppleUSBOpticalMouse 650.4.0
com.apple.driver.AppleHDA 2.6.3f7
com.apple.driver.AppleUpstreamUserClient 3.5.13
com.apple.driver.AppleMCCSControl 1.2.5
com.apple.kext.AMDFramebuffer 1.2.4
com.apple.iokit.IOUserEthernet 1.0.0d1
com.apple.ATIRadeonX2000 8.2.4
com.apple.Dont_Steal_Mac_OS_X 7.0.0
com.apple.driver.AppleHWAccess 1
com.apple.kext.AMD2600Controller 1.2.4
com.apple.driver.AppleLPC 1.7.0
com.apple.driver.AppleMCEDriver 1.1.9
com.apple.driver.ACPI_SMC_PlatformPlugin 1.0.0
com.apple.iokit.SCSITaskUserClient 3.6.7
com.apple.driver.XsanFilter 404
com.apple.iokit.IOAHCIBlockStorage 2.3.1
com.apple.driver.AppleUSBHub 683.4.0
com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 1.0.0d1
com.apple.driver.AppleIntel8254XEthernet 3.1.4b1
com.apple.AppleFSCompression.AppleFSCompressionTypeLZVN 1.0.0d1
com.apple.AppleFSCompression.AppleFSCompressionTypeZlib 1.0.0d1
com.apple.BootCache 35
com.apple.driver.AppleAHCIPort 2.5.2
com.apple.driver.AppleIntelPIIXATA 2.5.1
com.apple.driver.AppleFWOHCI 5.0.2
com.apple.driver.AppleUSBEHCI 660.4.0
com.apple.driver.AppleUSBUHCI 656.4.1
com.apple.driver.AppleACPIButtons 1.7
com.apple.driver.AppleRTC 2.0
com.apple.driver.AppleHPET 1.8
com.apple.driver.AppleSMBIOS 1.9
com.apple.driver.AppleACPIEC 1.7
com.apple.driver.AppleAPIC 1.6
com.apple.driver.AppleIntelCPUPowerManagementClient 217.92.1
com.apple.nke.applicationfirewall 153
com.apple.security.quarantine 3
com.apple.driver.AppleIntelCPUPowerManagement 217.92.1
com.apple.kext.triggers 1.0
com.apple.iokit.IOSerialFamily 10.0.7
com.apple.iokit.IOBluetoothHostControllerUSBTransport 4.2.7f5
com.apple.driver.DspFuncLib 2.6.3f7
com.apple.vecLib.kext 1.0.0
com.apple.driver.AppleSMBusController 1.0.11d0
com.apple.iokit.IONDRVSupport 2.4.1
com.apple.iokit.IOSurface 91.3
com.apple.iokit.IOAudioFamily 1.9.7fc2
com.apple.kext.OSvKernDSPLib 1.14
com.apple.iokit.IOBluetoothFamily 4.2.7f5
com.apple.driver.AppleHDAController 2.6.3f7
com.apple.iokit.IOHDAFamily 2.6.3f7
com.apple.kext.AMDSupport 1.2.4
com.apple.AppleGraphicsDeviceControl 3.6.22
com.apple.iokit.IOGraphicsFamily 2.4.1
com.apple.iokit.IOFireWireIP 2.2.6
com.apple.driver.AppleSMC 3.1.8
com.apple.driver.IOPlatformPluginLegacy 1.0.0
com.apple.driver.IOPlatformPluginFamily 5.7.1d6
com.apple.driver.AppleUSBHIDKeyboard 170.15
com.apple.driver.AppleHIDKeyboard 170.15
com.apple.iokit.IOUSBHIDDriver 660.4.0
com.apple.driver.AppleUSBMergeNub 650.4.0
com.apple.driver.AppleUSBComposite 656.4.1
com.apple.iokit.IOSCSIMultimediaCommandsDevice 3.6.7
com.apple.iokit.IOBDStorageFamily 1.7
com.apple.iokit.IODVDStorageFamily 1.7.1
com.apple.iokit.IOCDStorageFamily 1.7.1
com.apple.iokit.IOATAPIProtocolTransport 3.5.0
com.apple.iokit.IOSCSIArchitectureModelFamily 3.6.7
com.apple.iokit.IONetworkingFamily 3.2
com.apple.iokit.IOUSBUserClient 660.4.2
com.apple.iokit.IOAHCIFamily 2.3.1
com.apple.iokit.IOATAFamily 2.5.2
com.apple.iokit.IOFireWireFamily 4.5.5
com.apple.iokit.IOUSBFamily 686.4.1
com.apple.driver.AppleEFINVRAM 2.0
com.apple.iokit.IOHIDFamily 2.0.0
com.apple.driver.AppleEFIRuntime 2.0
com.apple.iokit.IOSMBusFamily 1.1
com.apple.security.sandbox 278.11.2
com.apple.kext.AppleMatch 1.0.0d1
com.apple.security.TMSafetyNet 7
com.apple.driver.AppleKeyStore 2
com.apple.driver.DiskImages 373
com.apple.iokit.IOStorageFamily 1.9
com.apple.iokit.IOReportFamily 23
com.apple.driver.AppleFDEKeyStore 28.30
com.apple.driver.AppleACPIPlatform 1.7
com.apple.iokit.IOPCIFamily 2.7.3
com.apple.iokit.IOACPIFamily 1.4
com.apple.kec.pthread 1
com.apple.kec.corecrypto 1.0
Model: MacPro3,1, BootROM MP31.006C.B05, 8 processors, Quad-Core Intel Xeon, 2.8 GHz, 2 GB, SMC 1.25f4
Graphics: ATI Radeon HD 2600 XT, ATI Radeon HD 2600, PCIe, 256 MB
Memory Module: DIMM Riser A/DIMM 1, 1 GB, DDR2 FB-DIMM, 800 MHz, 0x802C, 0x3138484631323837324A4438304544364434
Memory Module: DIMM Riser A/DIMM 2, 1 GB, DDR2 FB-DIMM, 800 MHz, 0x802C, 0x3138484631323837324A4438304544364434
Bluetooth: Version 5.2.7f4 15858, 3 services, 14 devices, 1 incoming serial ports
Network Service: Ethernet 1, Ethernet, en0
PCI Card: ATI Radeon HD 2600, Display Controller, Slot-1
PCI Card: pci1057,6, Slot-2@2,0,0
PCI Card: Universal Audio UAD-2 Solo, Other Multimedia, Slot-3
Serial ATA Device: ST1000DM005 HD103SJ, 1 TB
Serial ATA Device: WDC WD3200AAJS-41VWA1, 320.07 GB
Serial ATA Device: WDC WD3200KS-00PFB0, 320.07 GB
Serial ATA Device: Samsung SSD 840 Series, 250.06 GB
Parallel ATA Device: PIONEER DVD-RW DVR-112D
USB Device: Keyboard Hub
USB Device: Apple Optical USB Mouse
USB Device: Apple Keyboard
USB Device: 828 mk3
USB Device: Bluetooth USB Host Controller
USB Device: iLok
FireWire Device: built-in_hub, Up to 800 Mb/sec
Thunderbolt Bus:
Thanks,
Gavin
Mac OS version:
13F1911
Kernel version:
loaded kexts:
USB Device: 828 mk3
USB Device: iLok
Thunderbolt Bus:
Haven’t gone thru the thread again. Can you or have you tested your RAM? If not, I’d try removing some sticks and try starting.
If you google AppleMCEDriver and Fbd memory error, both of which appear in the error log, in addition to RAM issues, you'll also see references to problems associated with what appears to be your Mac and some graphics cards.
