I have a Yamaha Motif Rack ES. I'm trying to send patch changes to it.
I'm inserting a PATCH CHANGE and the Motif will change to the correct MSB and LSB but will not go to the Patch Number.
Example
Full Grand = MSB63, LSB0, Patch1
Ballad Key = MSB63, LSB0, Patch16
When I try to insert a "change to Ballad Key" command, it will always go to the first patch in the MSB/LSB bank (in this case, Full Grand).
It will never go to any patches below Patch 1 in any bank.
What am i doing wrong?
How to send patch changes in DP to older rack gear
Dual Quad-Core 2.8 GHz Mac Pro 3,1 • Yosemite • 24 GB RAM • MOTU 2408mk3 (x's 2) • DP 10.xx • Finale 25 • Logic • PT 12 • +outboard gear
Re: How to send patch changes in DP to older rack gear
Totally a guess, but don't you have to change the LSB value to other than zero?
Ballad Key = MSB63, LSB15, Patch16
Yes. I'm sorry I misspoke. The Yamaha LSB bank is 0 but in DP i enter "1" and it switches to that bank.
Even still, it won't patch change to anything other than the first patch of that Bank.
