New presonus Faderport
bjornln
Post by bjornln »
Hi,
You have probably seen this before.
But if not...there seems to be a new version out. 199$
https://www.presonus.com/products/FaderPort
/B
Macmini M1 | Motu 828mk3 x 1 | 2 x Motu M64 & SSL XLogic Alpha-Link MADI AX | 2 x Motu MTP AV | OSX 12.6.x | DP 11.x | Mach5 3.x.x | 2xiLok | 2xUAD quad dsp card | Altiverb 7.x | SoundToys | Nomad factory | PSP | Arturia V-collection | Korg VI's |
and loads n' loads n' loads n' loads n' loads o' stuff.
Re: New presonus Faderport
Post by Rick Cornish »
I like the one I have. DP integration is a little limited, but it does what I need. I only wish it had a track name readout like AlphaTrack.
waxman
Post by waxman »
Is the new one compatible with DP?
waxman
waxman wrote:Is the new one compatible with DP?
Yes, but I would contact Presonus for details.
EMRR
Post by EMRR »
Hmm, have to keep an eye on this, thanks.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
Sedaray
Post by Sedaray »
I bought one. Got DP 9.5.2 to recognize it in two ways in the Control Surface setup; but it doesn't do anything in DP.
Presonus forum says DP is not recognized in 64bit and gives no more help.
Sending it back.
MartinBaird
Post by MartinBaird »
PreSonus FaderPort has been tested and approved to work with the following software:
Native Mode
PreSonus Studio One® 3.5.6 with extension*** or Studio One 4.0.1 or later
HUI Emulation
Supported by Pro Tools
Mackie Universal Control Emulation**
Supported by Logic, Cubase, Nuendo, and Ableton
** Users of third-party DAWs not listed that support the Mackie Control protocol, such as Reason, Bitwig Studio, and Reaper, should contact their DAW vendor for support.
Martin Baird
martin@vmw.us
DP 11, MachFive, Electric Keys, 828es, MTP A/V USB
Mac Studio
daveyboy
Post by daveyboy »
Is anyone using the “new” Faderport in DP successfully? My Alphatrack currently doesn’t work in DP11 (still works in 10) and the older Faderport is sketchy. I don’t mind getting the newer Faderport if indeed it actually works.
Dave
www.dbwproductions.com
shelly_the_turtle
Post by shelly_the_turtle »
Just figured out how to get my older Faderport to work in DP 11. Go to Setup => Control Surface Setup. Set the Driver to HUI, and Track Filtering to Pin to Focus Window. Input Port to FaderPort-1, Output Port to FaderPort. PIN TO FOCUS WINDOW was the real fix here... it was default set to Pin to Mixer when I switch to 11 from 10. Hope this works for you too, and perhaps try the same method for your Alphatrack!
Cheers!
