New presonus Faderport
Hi,
You have probably seen this before.
But if not...there seems to be a new version out. 199$
https://www.presonus.com/products/FaderPort
/B
/B
Re: New presonus Faderport
I like the one I have. DP integration is a little limited, but it does what I need. I only wish it had a track name readout like AlphaTrack.
Is the new one compatible with DP?
waxman
Yes, but I would contact Presonus for details.waxman wrote:Is the new one compatible with DP?
Hmm, have to keep an eye on this, thanks.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.34
I bought one. Got DP 9.5.2 to recognize it in two ways in the Control Surface setup; but it doesn't do anything in DP.
Presonus forum says DP is not recognized in 64bit and gives no more help.
Sending it back.
Sending it back.
PreSonus FaderPort has been tested and approved to work with the following software:
Native Mode
PreSonus Studio One® 3.5.6 with extension*** or Studio One 4.0.1 or later
HUI Emulation
Supported by Pro Tools
Mackie Universal Control Emulation**
Supported by Logic, Cubase, Nuendo, and Ableton
** Users of third-party DAWs not listed that support the Mackie Control protocol, such as Reason, Bitwig Studio, and Reaper, should contact their DAW vendor for support.
Native Mode
HUI Emulation
- daveyboy
Is anyone using the “new” Faderport in DP successfully? My Alphatrack currently doesn’t work in DP11 (still works in 10) and the older Faderport is sketchy. I don’t mind getting the newer Faderport if indeed it actually works.
Dave
www.dbwproductions.com
Just figured out how to get my older Faderport to work in DP 11. Go to Setup => Control Surface Setup. Set the Driver to HUI, and Track Filtering to Pin to Focus Window. Input Port to FaderPort-1, Output Port to FaderPort. PIN TO FOCUS WINDOW was the real fix here... it was default set to Pin to Mixer when I switch to 11 from 10. Hope this works for you too, and perhaps try the same method for your Alphatrack!
Cheers!
Cheers!
