the cause of stuck MIDI notes
philbrown
Post by philbrown »
Has there ever been a definitive answer of what causes stuck MIDI notes? This used to be something we heard about a lot here but not so much lately. I haven't had a stuck note for literally years until I bought Sonivox Orchestral Companion strings- stuck notes seem to be its main feature. Since I have lots of other VI's I can only assume its this particular plug and not DP but no way of knowing for sure. Anyway I was just curious of there was ever any conclusion made on this issue in general besides specific plug issues.
tommymandel
Re: the cause of stuck MIDI notes
Post by tommymandel »
I picked up that VI too, Phil, and the only stuck note I got on it was in their Contrabass, and it may have had something to do with the note length bar extending over a measure line, either recorded or playing back in a loop, where this note extended past the end loop point, even when I changed the loop's end marker. But it is mostly working well, without stuck notes here.
DP 11.32 12core(5,1): 64GB/10.14.6, two 24i/o's, two 2408mk3's, 4pre, MicroLite-- MBP 2015 16GB/ 2TB 'Blade SSD 10.14.4, Mainstage, Numa C2x, ReMOTE SL -- 32 Lives, Pro-53, SampleTron,Keyscape,MTronPro,RolCloud,Icarus,Dune,OB-E; Clearmountain Domain,Soundtoys,AdrenaLinnSync, LinnSequencers,Tempest, Montage, JU80, Sledge, Prophet-X, T8, OB-6 V-Synth, s70xs, D-50, TS-10, JD800, Karma, Pa-1x B3, Wurly, Mason Hamlin.
The cause of stuck notes is explained here.
labman
Post by labman »
MIDI Life Crisis wrote:The cause of stuck notes is explained here.
:rofl:
