I'm trying out a new vertical Evoluent mouse but it seems I need to remove the Logitech driver (which is implemented as a system prefs pane) before the new one will work. I really want to save all my custom settings for the Logitech Performance MX mouse in case I want to go back to it, but I can't figure out where that stuff is stored. I've done quite a search, including the net but haven't turned up anything. Once I remove the driver from system prefs I'm assuming I'd have to reinstall from scratch and recreate all my custom settings.
TIA, (also my dog's name)
Phil
Where are system prefs stored? Logitech driver
- philbrown
Re: Where are system prefs stored? Logitech driver
I'd check both the user and system Library/Application Support folders for starters.
- philbrown
Good suggestion MLC. I found some files but nothing that resembles prefs though. There were some apps and an XML file that was mostly empty. I think I'll just take a bunch of screen shots of my settings. I may switch to Steermouse before this is all over anyway.MIDI Life Crisis wrote:I'd check both the user and system Library/Application Support folders for starters.
I stopped using a mouse about 9 months ago. Steer Mouse kept loosing the connection and there wasn't a great alternative to my aged Revolution MX. The Magic Trackpad 2 has been great. Don't miss the mouse (hardly) at all.
On my system, if I change something in the preferences panel, the file:philbrown wrote:I'm trying out a new vertical Evoluent mouse but it seems I need to remove the Logitech driver (which is implemented as a system prefs pane) before the new one will work. I really want to save all my custom settings for the Logitech Performance MX mouse in case I want to go back to it, but I can't figure out where that stuff is stored. I've done quite a search, including the net but haven't turned up anything. Once I remove the driver from system prefs I'm assuming I'd have to reinstall from scratch and recreate all my custom settings.
Phil
~/Library/Preferences/com.apple.systempreferences.plist
gets modified.
(~/ represents your user folder)
Chuck
iMac (Retina 4K, 21.5-inch, 2017)|| 16GB Ram || OS/X 10.14.6 || Motu 828MkII || Steinberg UR242 || DP8.07
Macbook Pro (Retina, 13-inch), 2.7 GHz i5, 8GB Ram
Chuck
