Where are system prefs stored? Logitech driver
philbrown
Post by philbrown »
I'm trying out a new vertical Evoluent mouse but it seems I need to remove the Logitech driver (which is implemented as a system prefs pane) before the new one will work. I really want to save all my custom settings for the Logitech Performance MX mouse in case I want to go back to it, but I can't figure out where that stuff is stored. I've done quite a search, including the net but haven't turned up anything. Once I remove the driver from system prefs I'm assuming I'd have to reinstall from scratch and recreate all my custom settings.
TIA, (also my dog's name)
Re: Where are system prefs stored? Logitech driver
I'd check both the user and system Library/Application Support folders for starters.
philbrown
Post by philbrown »
MIDI Life Crisis wrote:I'd check both the user and system Library/Application Support folders for starters.
Good suggestion MLC. I found some files but nothing that resembles prefs though. There were some apps and an XML file that was mostly empty. I think I'll just take a bunch of screen shots of my settings. I may switch to Steermouse before this is all over anyway.
I stopped using a mouse about 9 months ago. Steer Mouse kept loosing the connection and there wasn't a great alternative to my aged Revolution MX. The Magic Trackpad 2 has been great. Don't miss the mouse (hardly) at all.
cleamon
Post by cleamon »
philbrown wrote:I'm trying out a new vertical Evoluent mouse but it seems I need to remove the Logitech driver (which is implemented as a system prefs pane) before the new one will work. I really want to save all my custom settings for the Logitech Performance MX mouse in case I want to go back to it, but I can't figure out where that stuff is stored. I've done quite a search, including the net but haven't turned up anything. Once I remove the driver from system prefs I'm assuming I'd have to reinstall from scratch and recreate all my custom settings.
On my system, if I change something in the preferences panel, the file:
~/Library/Preferences/com.apple.systempreferences.plist
gets modified.
(~/ represents your user folder)
Chuck
iMac (Retina 4K, 21.5-inch, 2017)|| 16GB Ram || OS/X 10.14.6 || Motu 828MkII || Steinberg UR242 || DP8.07
Macbook Pro (Retina, 13-inch), 2.7 GHz i5, 8GB Ram
