Solved - DP 9.1 Project defaulting to frames instead of meas
primeevolutionary
Post by primeevolutionary »
Since I installed 9.1, every time I open a project the counter is defaulting to frames instead of measures.
And measures are no longer showing up in the Event List.
Last edited by primeevolutionary on Fri Sep 23, 2016 7:06 am, edited 1 time in total.
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
Phil O
Re: DP 9.1 Project defaulting to frames instead of measures
Post by Phil O »
Have you checked your settings in the Time Formats window (Settings>Time Formats)? I haven't messed with that window for a while so I'll just refer you to the manual. Chapter 7 in PDF User Guide.
primeevolutionary
Re: DP 9.1 Project defaulting to frames instead of meas - SO
Thanks, Phil O. I assumed it had to be something easy, but, I went through all of the Preferences. I don't believe I've ever visited Time Formats before.
It makes me very nervous about what else may have changed after the installation.
Thanks again!
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
Phil O
Post by Phil O »
Glad to help.
