Reading one of these threads on reverbs I realized I have never used Pro Verb. I downloaded some free IRs. I'm an avowed Altiverb user. But what the hell. Can always use something else too. I have all these IRs but no place to put them. I read the manual and it says user/library/MOTU/ProVerb/Impulse Responses. That's it. There is no such folder. What do I have to do to install these IRs?
How do I install them and use them? Thanks in advance.
DP9
Pro Verb - where do the user IRs go?
- Henry Robinett
All the best,
Henry Robinett
2019 Mac Pro 16 core, 192 GB; 2 MacPro 5,1 Metric Halo ULN-8 3d (x6), ULN-2-3d, MIDI Express XT,
DP10.13, UAD2 Quad TB,Duo,solo, Fractal Ax Fx III, FM3, LF+12+, Altiverb 7, Pianoteq7, Falcon, Keyscape, Omnisphere, Kontakt 5, Superior Drummer 3, Slate Drums, Live 10, Battery4, Diva, Spitfire Chamber and Symphony Strings, Ivory 2, Spectrafoo, Millennia HV3-D, many mics, many guitars . . ..
Henry Robinett
Re: Pro Verb - where do the user IRs go?
drag and drop into the proverb UI window -
I believe you need to match the type - if ProVerb's output is mono then you'll need a mono impulse
http://www.motunation.com/forum/viewtop ... ze#p507734
MacBook Pro 9,1 15" 16gb | 10.12.4 | DP 9.13 | xAir | NI | WIVI | Garritan | Izotope | Bidule
- Henry Robinett
Every time I go to the finder to get the file I want to drag and drop PV disappears. I go back to DP, close mixer, TO to make it easy to find, back to finder and PV disappears again. I can't figure out how to drag and drop.
All the best,
Henry Robinett
Henry Robinett
Hmm. When I open the ProVerb window, it stays open as a move to Finder.
I'm double-clicking on it from the mixer insert to open the window.
I wonder if there is a preference to keep that window open somehow.
Dragging the IR's so the ProVerb window allows MOTU to "import" and configure as necessary, so it make sense (as opposed to populating a folder).
Having inputs and outputs assigned is also a pre-requisit to doing anything with ProVerb.
Analog is great... We got both WOW and Flutter - what's your bias?
MOTU: DP9 - 2 x MachV - 2 x MX4 - 2 x 1296 - 2 x 896HD - 1 x UltraLite AVB - 1 x MOTU Monitor 8 - 1 x 24i - 3 x MTP AV | UA Apollo Quad | UA Arrow | SSL 2+ || Digi 002Rack | Mackie control + expanders | UAD-2 PCIe card | 2 x Mac Pro | Mac Mini Late 2018 | OS X 10.14.6
