Pro Verb - where do the user IRs go?
Henry Robinett
Post by Henry Robinett »
Reading one of these threads on reverbs I realized I have never used Pro Verb. I downloaded some free IRs. I'm an avowed Altiverb user. But what the hell. Can always use something else too. I have all these IRs but no place to put them. I read the manual and it says user/library/MOTU/ProVerb/Impulse Responses. That's it. There is no such folder. What do I have to do to install these IRs?
How do I install them and use them? Thanks in advance.
DP9
All the best,
Henry Robinett
reedster
Re: Pro Verb - where do the user IRs go?
Post by reedster »
drag and drop into the proverb UI window -
I believe you need to match the type - if ProVerb's output is mono then you'll need a mono impulse
http://www.motunation.com/forum/viewtop ... ze#p507734
MacBook Pro 9,1 15" 16gb | 10.12.4 | DP 9.13 | xAir | NI | WIVI | Garritan | Izotope | Bidule
Henry Robinett
Every time I go to the finder to get the file I want to drag and drop PV disappears. I go back to DP, close mixer, TO to make it easy to find, back to finder and PV disappears again. I can't figure out how to drag and drop.
All the best,
Henry Robinett
Hmm. When I open the ProVerb window, it stays open as a move to Finder.
I'm double-clicking on it from the mixer insert to open the window.
I wonder if there is a preference to keep that window open somehow.
Dragging the IR's so the ProVerb window allows MOTU to "import" and configure as necessary, so it make sense (as opposed to populating a folder).
Having inputs and outputs assigned is also a pre-requisit to doing anything with ProVerb.
Basstrup
Post by Basstrup »
Here my explanation
https://youtu.be/kV9melNXc08
Analog is great... We got both WOW and Flutter - what's your bias?
MOTU: DP9 - 2 x MachV - 2 x MX4 - 2 x 1296 - 2 x 896HD - 1 x UltraLite AVB - 1 x MOTU Monitor 8 - 1 x 24i - 3 x MTP AV | UA Apollo Quad | UA Arrow | SSL 2+ || Digi 002Rack | Mackie control + expanders | UAD-2 PCIe card | 2 x Mac Pro | Mac Mini Late 2018 | OS X 10.14.6
