Mavericks, DP7.24 and BFD, Autotune 7 issues
Timeline
Post by Timeline »
Auto tune 7 will not display GUI when selected from an insert. BFD's latex download crashes the system and crash report claims carbon the problem. Been trying to get system straight for a week now since Mavericks crashed my system. Apparently from old remaining files in system.
http://www.eirec.com/AutotuneIssues Will show results when I get Fetch to work later. Cheers, GB
Re: Mavericks, DP7.24 and BFD, Autotune 7 issues
crash report claims carbon is the problem
The crash report is right.
This has nothing to do with Mavericks, BTW.
If the host application uses Carbon based graphics (DP 7.x) but the plugin requires a host that uses Cocoa (DP 8.x), this will happen.
The fix is to update to DP 8.
Read the following from Izotope. BTW, they have re-enabled Carbon support in some of their plugs. Ozone 5 - 5.03 and 5.05b work in DP 7 but 5.04 does not. Some of their plugs no longer work in DP 7 - you have to go back to slightly earlier versions (Nectar 2.01 works; 2.02 does not).
http://www.izotope.com/support/portal/i ... ugin_hosts
DSP-Quatro has the same issue and users will have to wait until the Cocoa based rewrite is complete. Applications cannot be patched when this occurs.
Timeline
Post by Timeline »
Thanks Mike. Was feeling all alone up here. Here is another issue I'm having that has me stopped dead in my tracks. In Mavericks, I cannot throughput MIDI though to a VI yet the older sessions made in ML play MIDI though to the VI's. An Apple tech said it could be my machine, early 2009. I can see the MIDI keyboard on the MIDI monitor but not on MIDI fader in record. Weird huh.
Timeline
Post by Timeline »
Here is the prominent section of Antaries-Tech Autotune 7 Crash report: See the words carbon and FXpansion?
Process: Digital Performer [392]
Path: /Applications/Digital Performer 7.24.app/Contents/MacOS/Digital Performer
Identifier: com.motu.DigitalPerformer
Version: 7.24 (7.24)
Code Type: X86 (Native)
Parent Process: launchd [207]
Responsible: Digital Performer [392]
User ID: 501
Date/Time: 2014-02-19 07:45:38.156 -0600
OS Version: Mac OS X 10.9.1 (13B42)
Report Version: 11
Anonymous UUID: 1067C1D3-6F8E-7E5A-93AB-BF4E3CF9547C
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
VM Regions Near 0:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/Digital Performer 7.24.app/Contents/MacOS/Digital Performer
__TEXT 0000000000001000-0000000000b94000 [ 11.6M] r-x/rwx SM=COW /Applications/Digital Performer 7.24.app/Contents/MacOS/Digital Performer
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.FXpansion.BFD2 0x29673ad4 CVST2AUView::CreateCarbonView(ComponentInstanceRecord*, OpaqueWindowPtr*, OpaqueControlRef*, Float32Point const&, Float32Point const&, OpaqueControlRef*&) + 572
1 com.FXpansion.BFD2 0x296827a7 AUCarbonViewBase::ComponentEntryDispatch(ComponentParameters*, AUCarbonViewBase*) + 301
2 com.FXpansion.BFD2 0x29672812 ComponentEntryPoint<CVST2AUView>::Dispatch(ComponentParameters*, CVST2AUView*) + 253
3 com.apple.CoreServices.CarbonCore 0x997ceee5 CallComponent + 166
4 com.apple.CoreServices.CarbonCore 0x997cef3f CallComponentDispatch + 29
5 com.apple.audio.toolbox.AudioToolbox 0x97953f11 _AT_AudioUnitCarbonViewCreate + 73
6 com.MOTU.MAS.AudioUnitSupport 0x156492d8 MasAUSupportCarbonWindowImpl::InstallViewComponent(ComponentDescription&) + 328
Timeline
Post by Timeline »
I loaded the DP 8 demo and now without reloading any plugs, DP8.05 cleared up the crashing which means DP 7.24 is not totally compatible with these plugs, AFAICS.
The USB MIDI not making to a mmidi fader is still unsolved. Called MOTU and they seem stumped as well.
