NanoSampler Broken in DP 8?
Babz
Post by Babz »
If I drag a WAV file into the Nanosampler window, the name appears below, but no waveform appears in the window and I get no sound. However, I can get it to play its presets. Is Nanosampler broken in DP 8.0.4? I have rarely used it, so maybe I'm doing something wrong?
Thx,
Babz
Re: NanoSampler Broken in DP 8?
Sorry there is no definitive answers, yet, but does the sample rate of the sample match the project? Otherwise I got nothing.
Babz
Post by Babz »
16 bit WAV dragged into a 24 bit project. But this should work, shouldn't it? I'm sure I was able to do this in the past.
I have tried dragging from the Finder, importing using menu, and trying to drag a soundbite from the tracks window.
Is it working for you? Can you drag a WAV file into the Nanosampler window and get it to play?
Thx,
Babz
(Love your avatar, cuttime :)
reedster
Post by reedster »
.wav files not playing back over here.
they seem to import, but are grayed out in:
project / Plug-In Data / nanosampler
.aif files work as expected
Comparing the file types with Get Info, under the More Info tab for the .wav there's no data.
MacBook Pro 9,1 15" 16gb | 10.12.4 | DP 9.13 | xAir | NI | WIVI | Garritan | Izotope | Bidule
reedster
Post by reedster »
Seems like Nano may be corupting wav files on import.
If I drag the wav file directly into the
project / Plug-In Data / nanosampler folder and load it through the Nano drop down menu, under Project, the sample plays back as expected.
Babz
Post by Babz »
Thanks, reedstar!
I guess I will contact MOTU on Monday. For now I guess the workaround is to convert my files to AIF first? I will also try the folder method you mention.
Amazing something so basic could slip by beta testers! I guess nobody really uses Nanosampler and that's why this problem hasn't been reported till now.
Babz
reedster
Post by reedster »
direct into the folder saves a step and creates one less version.
the nano is pretty handy, low overhead, if there was a way to route LFO to amplitude that would make it tons more groovy. With Device Groups several Nano's can be stacked together - it's not hard to build up interesting sounds.
While they are functional, NRPNs are not the most convenient way to use physical controls with the Nano. For such a few number of parameters "learn controller mapping" like Modulo does it, likely would be simpler.
Seem to recall a limit on sample length that seemed arbitrary.
good luck.
reedster
Babz
Post by Babz »
Will try a shorter sample. This one is maybe 8-10 seconds long.
Best,
Babz
Tritonemusic
Post by Tritonemusic »
reedster wrote:Seem to recall a limit on sample length that seemed arbitrary.
The limit was 20 seconds (I'm still on 7.24). In 7.24, you can still import a longer sample, but it stops playback at 20 seconds, FWIW.
DP 10.13, OS 13.7.5, iMac Pro (2017) 3.2 GHz 8-Core, 32 GB RAM, MOTU M4
NeilBlack
Post by NeilBlack »
I was having loads of problems with spiking etc on some recents projects. I finally narrowed it down to nanosampler and had to render the audio then scrap it.
I also have problems with Polar regularly crashing DP8.
DP10.1 MacPro 5.1 Hex OSX 10.14.6 24GB Ram. UA Apollo. ProAc Studio 100's. Neumann KH120's Neumann 84's / AKG / Crowley & Tripp / NTK Jolly mod. Focusrite, TLA, GAP mic pre's. Maschine 2
