FMiguelez wrote:Does disabling and then enabling the VSL VI (the connection window) make a difference?
When mine don't connect automatically (for other reasons), that's what it takes me to reconnect them, even if they are in a V-Rack, like mine.
No, it's that I saved the document with all the VE Pro instances connected, but when I pull up a document, each VEP plugin says "not connected". I can hit the connection button and connect with the corresponding server/instance, and all the data is there, which means that the plugin remembered everything.. just not that it is supposed connect automatically when the document is opened.
This may not seem like a big deal, but it is. I just finally got all the bundles in my current DP documents to be correct, which meant going in and redoing ALL the bundles for EVERY document, by hand, one grid mouse click at a time. This, on account of going to Mountain Lion with my RME MADI card. I just don't want to have to pull everything up again and fix it manually before I can work on it. Uuuuggghhh!
