Some MachFive Samples won't load
- bkshepard
I have MachFive 3 (latest update), and also had MachFive 2. I'm finding that a few of the sounds that came with the v. 2 libraries won't load for me. A specific one as an example:
MachFive 2DVD4-VSL_Orch -> 01 Violin ensemble -> 01 Standard Instruments -> Violin ens 14 (all).m5p. I can load any of the other violin ensembles from the Standard Instruments subfolder except this one and Violin ens 14 (sustain).m5p. I have similar issues with files from other subfolders.
I've tried it as both a standalone and in DP8, and I've reinstalled the library.
Any suggestions? Thanks!
-Brian
Mac M1 Ultra 20-core, OS 14.6.1, 128 GB RAM, DP 11.3.2, UA Apollo x6
- FMiguelez
Re: Some MachFive Samples won't load
The first things I'd try are to check permissions and ownership.
Go to MF3's root folder and get it's info window. Set the permissions for your account to read/write, and make sure you make them apply to all enclosed files/folders.
For the ownership, you could go to the HD's root and click "ignore ownership in this volume".
Does that make a difference?
- bkshepard
Thanks for the suggestion FM. I actually had it that way already. The odd thing is that most of the samples in that library will load, it's just a few of them.
-Brian
Same here. I tried that patch and it didn't work. Looks like it's loading but the samples are MIA.
- bkshepard
When you select one of the samples that loads, the little status bar window opens for a few seconds as it chugs along loading the samples, but with this one, that little window is only open for about 100ms. Sounds like it might be a reproducible problem. Thanks for checking!
-Brian
- bkshepard
I've submitted a TechLink on this.
-Brian
I was able to open them in M5-2 but not save them (probably since I'm on ML). The samples are there, but M5-3 isn't seeing them. I also had to launch DP8 in 32 bit (heavens to Murgatroyd!) to access M5-2 but it seems less than fully functional. Still, as you indicated, some of the sounds load from the same bank. Weird.
Interesting stuff. I'm in the process of saving certain certain 'presets with samples' in Mach Five 2, so I can (in turn) load them into Mach Five 3. Reason being that Mach Five 2 will still read the presets from Mach Five One, which I've had for almost 10 years. We'll see what happens.
Mac Studio Ultra 64gb; Motif 8; Novation Summit, Yamaha MOXF6, Mach Five Three; Altiverb, UVI Stuff, Acoustic Legends; Plugsound Pro; Fender Strat; Stylus, Omnisphere 2.8, Trillian
- bkshepard
Got a reply to my TechLink that they were able to reproduce the problem and forwarding it on to the programming folks to be fixed.
-Brian
interesting.
Thanx bk
I've noticed a few that appear to be doa. Not like I would actually need them though. : )
mvh
mvh
