Some MachFive Samples won't load
bkshepard
Post by bkshepard »
I have MachFive 3 (latest update), and also had MachFive 2. I'm finding that a few of the sounds that came with the v. 2 libraries won't load for me. A specific one as an example:
MachFive 2DVD4-VSL_Orch -> 01 Violin ensemble -> 01 Standard Instruments -> Violin ens 14 (all).m5p. I can load any of the other violin ensembles from the Standard Instruments subfolder except this one and Violin ens 14 (sustain).m5p. I have similar issues with files from other subfolders.
I've tried it as both a standalone and in DP8, and I've reinstalled the library.
Any suggestions? Thanks!
-Brian
Mac M1 Ultra 20-core, OS 14.6.1, 128 GB RAM, DP 11.3.2, UA Apollo x6
FMiguelez
Re: Some MachFive Samples won't load
Post by FMiguelez »
The first things I'd try are to check permissions and ownership.
Go to MF3's root folder and get it's info window. Set the permissions for your account to read/write, and make sure you make them apply to all enclosed files/folders.
For the ownership, you could go to the HD's root and click "ignore ownership in this volume".
Does that make a difference?
bkshepard
Post by bkshepard »
Thanks for the suggestion FM. I actually had it that way already. The odd thing is that most of the samples in that library will load, it's just a few of them.
-Brian
Same here. I tried that patch and it didn't work. Looks like it's loading but the samples are MIA.
bkshepard
Post by bkshepard »
When you select one of the samples that loads, the little status bar window opens for a few seconds as it chugs along loading the samples, but with this one, that little window is only open for about 100ms. Sounds like it might be a reproducible problem. Thanks for checking!
-Brian
bkshepard
Post by bkshepard »
I've submitted a TechLink on this.
-Brian
I was able to open them in M5-2 but not save them (probably since I'm on ML). The samples are there, but M5-3 isn't seeing them. I also had to launch DP8 in 32 bit (heavens to Murgatroyd!) to access M5-2 but it seems less than fully functional. Still, as you indicated, some of the sounds load from the same bank. Weird.
VitcoMusic
Post by VitcoMusic »
Interesting stuff. I'm in the process of saving certain certain 'presets with samples' in Mach Five 2, so I can (in turn) load them into Mach Five 3. Reason being that Mach Five 2 will still read the presets from Mach Five One, which I've had for almost 10 years. We'll see what happens.
Mac Studio Ultra 64gb; Motif 8; Novation Summit, Yamaha MOXF6, Mach Five Three; Altiverb, UVI Stuff, Acoustic Legends; Plugsound Pro; Fender Strat; Stylus, Omnisphere 2.8, Trillian
bkshepard
Post by bkshepard »
Got a reply to my TechLink that they were able to reproduce the problem and forwarding it on to the programming folks to be fixed.
-Brian
geardada
Post by geardada »
interesting.
wylie1
Post by wylie1 »
Thanx bk
dpg4macman
Post by dpg4macman »
I've noticed a few that appear to be doa. Not like I would actually need them though. : )
mvh
