Digital performer and native instruments MIDI problem
Hi, I´m new here and I hope some of you guys can give me some help.
I´m having a strange issue with DP8 and NI stuff. When I create two or more consecutive notes of the same pitch and duration, either on the MIDI or quickscribe editor, the first note plays just fine but the other ones that follow become muted.
This only seems to happen when I´m using NI instruments like kontakt and massive, as far as i can tell it doesn´t happen with the bundled DP plugins.
The NI plugins are up-to-date, i´ve made the same test on logic, and all of them work just fine.
I managed to solve the problem nudging the notes by 1 tick, but this is really unproductive, especially when working on the Quickscribe editor, having to go back an forth nudging one of the two quarter notes just inserted...
I had the same issue with DP 7.24 and I tought this would be sorted out on the new update. Anybody has this same issue? Sorry for the long post…
Re: Digital performer and native instruments MIDI problem
This is a very common problem with many different VIs. Why not just shorten the duration of the notes by a tick in the entire region in one fell awoop?
828x MacOS 14.7.6 M1 Studio Max 1TB 64G DP11.34
It's a royal PITA on cymbals. I just add a second VI track when necessary and throw the extra notes onto a different channel. Who could it hurt?
It´s strange that this only happens with DP, because i´ve made the same test with the same plug-ins on logic and r.e.a.p.er. Maybe there´s a way that i´m missing to specify the standard note values in ticks?
DP seems to handle MIDI differently than other daws...
- greg328
Just select all concerned notes and use "change duration" menu command to shorten all by your chosen value. Simple.
- buzzsmith
Yep. Do it almost daily.greg328 wrote:Just select all concerned notes and use "change duration" menu command to shorten all by your chosen value. Simple.
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
I hate this too. subtracting clicks from duration is my only answer (as others have said)
Yes, it does in this one instance. IIRC, when a Note On and a Note Off occur at the same time, most DAWs send the Off first, then the On. It appears that DP does the opposite. I can't see any good reason to do it this way.hkappa wrote:DP seems to handle MIDI differently than other daws...
Even simpler just insert the duration plug-in on the MIDI track and specify 'add -1 tick'.greg328 wrote:Just select all concerned notes and use "change duration" menu command to shorten all by your chosen value. Simple.
Even more simpler; make this a clipping
.Bzz...
Mac Pro 6 Core-10.14.6-32GB | DP 10 | 828mkII fw | Receptor 1&2 |Reason 10.2 | Goliath | EWQLSO Gold | QL RA | Voices of Passion | Ocean Way Drums Platinum | SSD-EX | Chris Hein Horns 1&2 | Komplete 12 | AAS - Ultra Analog | BS Accordions | Nomad Factory Integral Bundle | WaveArts Power Suite 5 | Izotope Music Production 3 | Variax 600| TD-8 Drums ||STUDIO››|| MacPro QuadCore-2.66-10.4.11-8GB | 828mk3 fw | 8Pre fw (X2)| MC Mix (X3) MC Control ||
- buzzsmith
Like.Buzzy wrote:Even simpler just insert the duration plug-in on the MIDI track and specify 'add -1 tick'.greg328 wrote:Just select all concerned notes and use "change duration" menu command to shorten all by your chosen value. Simple.
Another Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Once you get the CHANGE DURATION inserted (via clippings), then just option-command drag it to neighboring track inserts.
I appreciate all your answers. I think the best way is to really use the change duration plugin, it works great, Thanks Buzzy for the suggestion
Still, why DP doesn´t adjust the note on and off automatically is beyond me...
- Gravity Jim
Because DP is deadly accurate (in terms of MIDI timing and sample accuracy) and its designers assume tht you know what you want in a given track. Not all VI (or hardware synth) patches react the same way... DP doesn't fix your work automatically, because you may not want it to.hkappa wrote:I appreciate all your answers. I think the best way is to really use the change duration plugin, it works great, Thanks Buzzy for the suggestion
Jim Bordner
I don't think that's the reason, although it may be quite true. Accuracy would not suffer if DP was changed, or an option was provided, to give Note Off priority instead of Note On priority, and playback would make more sense.Gravity Jim wrote:Because DP is deadly accurate (in terms of MIDI timing and sample accuracy) and its designers assume tht you know what you want in a given track. Not all VI (or hardware synth) patches react the same way... DP doesn't fix your work automatically, because you may not want it to.
Or what it's worth it's not just DP. Live is guilty as well.
A lot of soft synths have issues with the first note in a sequence if it's directly on 1|1|00 in a sort of related issue.
