Poor fitting USB cable, Microbook II
With very minor movement, it's extremely easy to interrupt the USB connection from my Microbook II.
Has anyone else experienced this with your unit?
iMac 2.66 GHz Intel core 2 duo, 8 gb ram running 10.11.6; 17" Macbook Pro 8,3, 2.5 GHz Core I7, 16 GB ram running 10.13.6; DP 8.07; 8pre-es; 828mkII; 828mkI; microbook II, Behringer ADA8000, Black Lion Auteur 2-Ch. Pre-Amp
Re: Poor fitting USB cable, Microbook II
My Track 16 has a fairly loose fitting FW connector. Slight movement disrupts the connection. Since I won the unit it's silly of me to complain to MOTU but had I bought it for $600 I'd be making a lot of noise.
My 828mk3 is like that.
I secure it with some gaff tape.
I need to buy more
I need to buy more
Get the 180' roll. Free delivery until Jan 1jonwormwood wrote:My 828mk3 is like that.
I need to buy more
http://www.leevalley.com/en/wood/page.a ... ,110,43466
A drop of rubber cement applied to the connection after it's plugged in works well and peals off easily when you want it to. Silicon seal works, too but takes a lot longer to set.
The thick stuff for stationery, like Elmer's, works best. Avoid the thin stuff often found in auto parts stores - that's better for patching tires.
Just use a drop on the side - like Brylcreme, "A little dab'll do ya"
- FutureLegends
My 828mk3 FW is like that too.
Seems like MOTU needs to fix!
I was planning to use the 828mk3 for live shows (recording + backing tracks playback) but don't think I trust the unit for that...
Maybe they did fix it. My 828-3 FW connections are as snug as any FW connection.FutureLegends wrote:My 828mk3 FW is like that too.
- FutureLegends
Yes, maybe they did. And they use FW800 connections now also on their latest interfaces, no?
I think they do, but my 828 uses the FW 400.FutureLegends wrote:Yes, maybe they did. And they use FW800 connections now also on their latest interfaces, no?
