Poor fitting USB cable, Microbook II
nick danger
Post by nick danger »
With very minor movement, it's extremely easy to interrupt the USB connection from my Microbook II.
Has anyone else experienced this with your unit?
iMac 2.66 GHz Intel core 2 duo, 8 gb ram running 10.11.6; 17" Macbook Pro 8,3, 2.5 GHz Core I7, 16 GB ram running 10.13.6; DP 8.07; 8pre-es; 828mkII; 828mkI; microbook II, Behringer ADA8000, Black Lion Auteur 2-Ch. Pre-Amp
Re: Poor fitting USB cable, Microbook II
My Track 16 has a fairly loose fitting FW connector. Slight movement disrupts the connection. Since I won the unit it's silly of me to complain to MOTU but had I bought it for $600 I'd be making a lot of noise.
jonwormwood
Post by jonwormwood »
My 828mk3 is like that.
I secure it with some gaff tape.
I need to buy more
:shake:
jonwormwood wrote:My 828mk3 is like that.
I need to buy more
:shake:
Get the 180' roll. Free delivery until Jan 1
http://www.leevalley.com/en/wood/page.a ... ,110,43466
A drop of rubber cement applied to the connection after it's plugged in works well and peals off easily when you want it to. Silicon seal works, too but takes a lot longer to set.
The thick stuff for stationery, like Elmer's, works best. Avoid the thin stuff often found in auto parts stores - that's better for patching tires.
Just use a drop on the side - like Brylcreme, "A little dab'll do ya"
FutureLegends
Post by FutureLegends »
My 828mk3 FW is like that too.
Seems like MOTU needs to fix!
I was planning to use the 828mk3 for live shows (recording + backing tracks playback) but don't think I trust the unit for that...
FutureLegends wrote:My 828mk3 FW is like that too.
Maybe they did fix it. My 828-3 FW connections are as snug as any FW connection.
FutureLegends
Yes, maybe they did. And they use FW800 connections now also on their latest interfaces, no?
FutureLegends wrote:Yes, maybe they did. And they use FW800 connections now also on their latest interfaces, no?
I think they do, but my 828 uses the FW 400.
