iMac Core i7 too much for DP 7.2?
It's getting to be upgrade time and the i7 iMac looks like a great machine. But...
As DP7.2 is still not 64-bit, will having that much machine be overkill or should I be looking at the i5?
Your thoughts?
Right now I'm running a 2.8 gHz Core 2, 4 GB SDRAM. Main Plugs include Kontakt 4 and Garritan Orchestra 4
Your thoughts?
27-inch iMac 3.8GHz quad-core Intel Core i5 with Retina 5K display, Radeon Pro 580 8 GB, 40 GB 2400 MHz DDR4, 2.12 TB Fusion Drive
- FMiguelez
Re: iMac Core i7 too much for DP 7.2?
It greatly depends on what you want to do with DP now and in the FUTURE.
For me, there's no such thing as a computer being "too much" for DP
Are you going to be doing a few MIDI tracks using external synths?
ARe you going to be doing MIDI tracks with VIs?
Will you want to use tons of CPU-hungry plug-ins?
Will you have 150 audio track sessions?
No externals; all software.
Yes
Just the ones I mentioned.
Ah, there's the rub. I want full orchestrations. Think Richard Strauss.
Yes
- FMiguelez
If you are planning on doing serious work, and not feel limited, then I'd advise you to get the best machine you can afford.
Think of a machine that will stay "current" even within 2-3 years.
You'll probably need 2 or 3 hard disks (System, Audio, Samples). You want an iMac, so your options are more limited here. You want at least 2 HDs.
And as much RAM as you can afford. Try to get the biggest RAM sticks you can (or you'll end-up like me, with many useless 512 MB and 1 GB sticks).
Thanks.
I, too, have a 512k chip graveyard.
- sdfalk
Who cares if it's 64 bit now..it will be.
If I could get a 12 core Mac with 32gb of ram
I'd be all over that MF
A Metric Halo ULN8-3D…mmmmmmm
No such thing as "too much"
The only question: Is it enough?
Looking at your needs, I would think, get the i7, have the sSATA port installed by OWC. This will give you quite a few options for upgrading as your requirements increase.
It's still over a grand less than a new Mac Pro with the new 27" monitor that is coming out next month.
