iMac Core i7 too much for DP 7.2?
MIDICH1
Post by MIDICH1 »
It's getting to be upgrade time and the i7 iMac looks like a great machine. But...
As DP7.2 is still not 64-bit, will having that much machine be overkill or should I be looking at the i5?
Your thoughts?
Right now I'm running a 2.8 gHz Core 2, 4 GB SDRAM. Main Plugs include Kontakt 4 and Garritan Orchestra 4
27-inch iMac 3.8GHz quad-core Intel Core i5 with Retina 5K display, Radeon Pro 580 8 GB, 40 GB 2400 MHz DDR4, 2.12 TB Fusion Drive
FMiguelez
Re: iMac Core i7 too much for DP 7.2?
Post by FMiguelez »
It greatly depends on what you want to do with DP now and in the FUTURE.
For me, there's no such thing as a computer being "too much" for DP :)
Are you going to be doing a few MIDI tracks using external synths?
ARe you going to be doing MIDI tracks with VIs?
Will you want to use tons of CPU-hungry plug-ins?
Will you have 150 audio track sessions?
MIDICH1
Post by MIDICH1 »
No externals; all software.
Yes
Just the ones I mentioned.
Ah, there's the rub. I want full orchestrations. Think Richard Strauss.
FMiguelez
Post by FMiguelez »
If you are planning on doing serious work, and not feel limited, then I'd advise you to get the best machine you can afford.
Think of a machine that will stay "current" even within 2-3 years.
You'll probably need 2 or 3 hard disks (System, Audio, Samples). You want an iMac, so your options are more limited here. You want at least 2 HDs.
And as much RAM as you can afford. Try to get the biggest RAM sticks you can (or you'll end-up like me, with many useless 512 MB and 1 GB sticks).
MIDICH1
Post by MIDICH1 »
Thanks.
I, too, have a 512k chip graveyard.
sdfalk
Post by sdfalk »
Who cares if it's 64 bit now..it will be.
If I could get a 12 core Mac with 32gb of ram
I'd be all over that MF
A Metric Halo ULN8-3D…mmmmmmm
No such thing as "too much"
The only question: Is it enough?
Looking at your needs, I would think, get the i7, have the sSATA port installed by OWC. This will give you quite a few options for upgrading as your requirements increase.
It's still over a grand less than a new Mac Pro with the new 27" monitor that is coming out next month.
