Hello
I have to transfer old recordings at 192k/24 bit rez. I have 2 896HD's and a Lucid clock. when I use Logic or any other program to record into I can see the meters moving and the material gets recorded but I can not hear anything coming out of the monitors. If I playback at 96k (1/2 speed) audio comes through the monitors (at 1/2 speed). I don't understand why I can not hear anything at 192K. Does any one have an explanation for this
Thank you
Recording at 192k/24
Stewart Adam
http://www.creativeaudioworks.com
Mac Mini 2011
izotope RX Advanced
izotope Ozone 9
Cubase 10
DSP quatto
Motu 16A
Alesis M20 (2)
Sony DA-88
4 Otari MTR 10's
6 Marants 502 Cassette decks
2 Studer A710
Tascam 38-8
Foster M80 eight track
Mac Mini 2011
izotope RX Advanced
izotope Ozone 9
Cubase 10
DSP quatto
Motu 16A
Alesis M20 (2)
Sony DA-88
4 Otari MTR 10's
2 Studer A710
Tascam 38-8
Re: Recording at 192k/24
Which 896HD outputs are you using for monitoring? According to the manual, the main outputs mirror the headphones output at 4X sample rates. That's probably why you're not hearing anything. Track outputs in Logic are set to Output 1-2, which corresponds to analog 1-2 at 4X SRs.
- Dwetmaster
I'm not sure cue mix works @ 192khz...
Yes, it does. But I don't think this has anything to do with CueMix.Dwetmaster wrote:I'm not sure cue mix works @ 192khz...
Hi
I am using the Main mix outs, L-R XLR outs
Stewart
Stewart
Stewart Adam
Mac Mini 2011
izotope RX Advanced
izotope Ozone 9
Cubase 10
DSP quatto
Motu 16A
Alesis M20 (2)
Sony DA-88
4 Otari MTR 10's
2 Studer A710
Tascam 38-8
Mac Mini 2011
izotope RX Advanced
izotope Ozone 9
Cubase 10
DSP quatto
Motu 16A
Alesis M20 (2)
Sony DA-88
4 Otari MTR 10's
2 Studer A710
Tascam 38-8
