After a very intense chorus there is a bit of 'dabbling' that is out of time. The click file stops at this point, then restarts right when the band all comes back together. I saw that the nuendo guy had it setup so the bar alignment and tempo/meter all matched perfectly after the rubato noodling.
I was able to tempo/beat map the rubato passage and align the project to that section perfectly except for the feedback at the end of the solo where everything, timewise, goes absolutely wonky.
I need to be able to manually adjust my project so that the measures line up correctly. I attempted to look through the manual but I'm unsure of what terms I'm even looking for
