Setting arbitrary measure start time?
GloryisSilent
Post by GloryisSilent »
I'm importing a project from a nuendo user who consolidated everything basic wav files. The entire project was recorded to a click track.
After a very intense chorus there is a bit of 'dabbling' that is out of time. The click file stops at this point, then restarts right when the band all comes back together. I saw that the nuendo guy had it setup so the bar alignment and tempo/meter all matched perfectly after the rubato noodling.
I was able to tempo/beat map the rubato passage and align the project to that section perfectly except for the feedback at the end of the solo where everything, timewise, goes absolutely wonky.
I need to be able to manually adjust my project so that the measures line up correctly. I attempted to look through the manual but I'm unsure of what terms I'm even looking for :oops: If someone could tell me how I can do this, especially if there are various ways, or even just point me to the chapter of the manual that explains it I would be very thankful.
Jed
Re: Setting arbitrary measure start time?
Post by Jed »
I just asked a similar question (relating to pick-up beats),
Have a look at the "Set Chunk Start Time" command located in the "Sequence Menu" (pull down menu (small triangle)) just to the left of the time signature in the control panel. This should let you move the location of "Bar 1" around - either to the left (earlier) or right (later).
cheers, I hope this helps.
GloryisSilent
Jed wrote:I just asked a similar question (relating to pick-up beats),
thanks, but I need to move measures around in the middle of a song.
FMiguelez
Post by FMiguelez »
See Insert Measures in the manual. Also, look up the Snip command.
You can also copy/paste empty measures as needed.
Mr_Clifford
Post by Mr_Clifford »
GloryisSilent wrote: I saw that the nuendo guy had it setup so the bar alignment and tempo/meter all matched perfectly after the rubato noodling.
Best thing would be to get the Nuendo guy to send you a MIDI file of the project, which you could import the conductor track from. Then you'll have the exact same tempo/meter changes as he does.
Otherwise, you can use the 'change tempo' and 'adjust beats' functions to realign the bars with your music. Often a single bar with a much slower (or faster) tempo just before the music comes back in will be enough to line it up.
GloryisSilent
Great! Adjust/Record beats seems to be what I needed.
bOing
Post by bOing »
I thought that's what you wanted. Well...my work is done here. :)
Success is just one more plugin away! And happiness is as close as your next upgrade.
