Can i use my Traveler as a monitor switcher?
- alexweinstein000
i just added a pair of monitors to my setup, and before i run out and buy a dedicated device, i wanted to know if i could some how use my Traveler to act as a monitor switcher.
if Outputs 1-2 are my mains, and 3-4 are my second pair, can i tell DP with maybe an aux track, or CueMix Console to turn one on and one off?
-alex-
DP 5.13, Traveler, OS 10.4.11
-alex-
- Dwetmaster
If you want to manage it from DP, then you can easily do this by using dedicated aux bus to do it.
If you want to be able to do this from any programs then I'd suggest you get a presonus central station
- alexweinstein000
- alexweinstein000
- Dwetmaster
Bus everything to a Master aux then use two diferent sends from that Aux instead
- alexweinstein000
You should also consider using a stereo track instead of an auxliary track so you could also "bounce" in real-time. You can do this by recording everything to this stereo track and exporting the soundbite.
Just be careful and avoid clipping the stereo bus.
Mac Pro 2.66 + Mac OS X 10.4.11 + DP 5.13 + Universal Audio UAD-1e + APOGEE Ensemble + MOTU Traveler
- Dwetmaster
I prefer to keep My bouncing to a separate track. I find it easier to use cuemix's MixBack function to do live bounce.
Also having the bounce on a separate track allows for easy comparison between what's has been bounced and any adjustment you'd like to do.
get a cheap 1/4" balanced patchbay
http://www.ronmeza.com
Keystation 49e controller
