Can i use my Traveler as a monitor switcher?
alexweinstein000
Post by alexweinstein000 »
i just added a pair of monitors to my setup, and before i run out and buy a dedicated device, i wanted to know if i could some how use my Traveler to act as a monitor switcher.
if Outputs 1-2 are my mains, and 3-4 are my second pair, can i tell DP with maybe an aux track, or CueMix Console to turn one on and one off?
-alex-
DP 5.13, Traveler, OS 10.4.11
Dwetmaster
Post by Dwetmaster »
If you want to manage it from DP, then you can easily do this by using dedicated aux bus to do it.
If you want to be able to do this from any programs then I'd suggest you get a presonus central station
alexweinstein000
i am definitely using DP (5.13). how would you suggest i set it up?
alexweinstein000
does this mean that i would have to run a unity send off every track to my new bus? i can't seem to find any other way to get the input of the new aux track to be the same as the master buss.
-a-
Dwetmaster
Bus everything to a Master aux then use two diferent sends from that Aux instead
alexweinstein000
excellent. got it. thank you for your help.
-a-
estudios.sdb
Post by estudios.sdb »
You should also consider using a stereo track instead of an auxliary track so you could also "bounce" in real-time. You can do this by recording everything to this stereo track and exporting the soundbite.
Just be careful and avoid clipping the stereo bus.
Mac Pro 2.66 + Mac OS X 10.4.11 + DP 5.13 + Universal Audio UAD-1e + APOGEE Ensemble + MOTU Traveler
Dwetmaster
I prefer to keep My bouncing to a separate track. I find it easier to use cuemix's MixBack function to do live bounce.
Also having the bounce on a separate track allows for easy comparison between what's has been bounced and any adjustment you'd like to do.
homebilly
Post by homebilly »
get a cheap 1/4" balanced patchbay
el Ocho 2.8 running DP6 & RMX with M5II - 828mkII / el Quatro 2.66 running Vienna VI & Vienna Ensemble, RAX 2, M5II & L8 for VSL - 2408mkII / steiner MIDI EVI, Oberheim Xpander, M5II reading UVI .dats, Radium 61 controller
http://www.ronmeza.com
Paris mini studio : iMac 20" intel 2.66 core duo (spring 2009) DP 6.02 - Firebox running M5II & Independence Pro 2.1 connected to Mac Mini (spring 2009) - Firebox running L8, RAX 2, Independence 2.1, M M5II
Keystation 49e controller
