Anyone using Metric Halo ChannelStrip?
Anyone using this plugin?
For some reason the lowest value the delay section can be set at is 16ms and that renders it kinda useless (although the manual says it can be set fot 0ms delay). Either way, I guess the delay compensation doesn't work on this since it's more of a delay than latency. How can I deal with this?
I've noticed that if you are using busses, sometimes latency comp gets fouled up, especially if the project or buss was created with a previous version of DP.
I found a workaround--delete the buss and any related busses, reinstantiate them, and my latency problems went away.
Also, some plugs [L3 is one of them] seem to break latency comp when on a Mix/master aux or a master fader--I've found that this trick can fix that too.
Let me know if it works.
MacPro2.66/3GB/828mk3/Rosetta800/UAD-2Quad/Waves/
XYZ... your avatar is in a password protected directory of your server, hence making a popup log-in dialog to everyone visiting this thread. I'm going to go into your profile and delete the avatar link if I can. Please be careful about this and make sure if you post a avatar link in the future it is not in a password protected directory. Thanks.XYZ wrote:I've noticed that if you are using busses, sometimes latency comp gets fouled up, especially if the project or buss was created with a previous version of DP.
Oh, and Great that it worked for you!
I was doing some drums, and I can't live with the phasing that occurs, so I struggled with this for some time until I tried to replicate the problem with a new clean project and could not. The rest was just troubleshooting till I figured this out.
Oh, and yes, I have heard a number of people on the a waves related thread [may be on the Waves forum] complain that the Waves plugs are losing settings.
I'm using Waves AU on an Intel machine with 5.12 and do not have this problem.
