Anyone using Metric Halo ChannelStrip?
Noumenon
Post by Noumenon »
Anyone using this plugin?
For some reason the lowest value the delay section can be set at is 16ms and that renders it kinda useless (although the manual says it can be set fot 0ms delay). Either way, I guess the delay compensation doesn't work on this since it's more of a delay than latency. How can I deal with this?
jrdmcdnld
Post by jrdmcdnld »
I use CS in DP 4.6. The delay compensation does work with it. I just tested it - duplicated a track put CS on one and trim plug. Flipped the phase and got total cancelation.
Noumenon
Post by Noumenon »
strange. 'cause I always get problems, but might it have to do with ezdrummer then?
anyways, when I have CS on the drum tracks for ezd the drums won't align with the click.
jrdmcdnld
Post by jrdmcdnld »
Dumb question, but I'm covering all the bases: You have delay compensation checked in the settings?
Noumenon
Post by Noumenon »
yup!
but I've ruled CS out now.
I've noticed that ezd is still messed up even when CS is removed.
XYZ
Post by XYZ »
I've noticed that if you are using busses, sometimes latency comp gets fouled up, especially if the project or buss was created with a previous version of DP.
I found a workaround--delete the buss and any related busses, reinstantiate them, and my latency problems went away.
Also, some plugs [L3 is one of them] seem to break latency comp when on a Mix/master aux or a master fader--I've found that this trick can fix that too.
Let me know if it works.
MacPro2.66/3GB/828mk3/Rosetta800/UAD-2Quad/Waves/
XYZ wrote:I've noticed that if you are using busses, sometimes latency comp gets fouled up, especially if the project or buss was created with a previous version of DP.
XYZ... your avatar is in a password protected directory of your server, hence making a popup log-in dialog to everyone visiting this thread. I'm going to go into your profile and delete the avatar link if I can. Please be careful about this and make sure if you post a avatar link in the future it is not in a password protected directory. Thanks.
Noumenon
Post by Noumenon »
Spot on XYZ!
Removed L3 from the master buss and it all went back to normal :D
BTW. Might have been covered before, but is anyone else having problems with waves plugins loosing their settings when closing/opening a project in DP 5.12?
XYZ
Post by XYZ »
Sorry about that. Looks like you already deleted it.
I added some security to my website and did not fully comprehend the ramifications.
XYZ
Post by XYZ »
Oh, and Great that it worked for you!
I was doing some drums, and I can't live with the phasing that occurs, so I struggled with this for some time until I tried to replicate the problem with a new clean project and could not. The rest was just troubleshooting till I figured this out.
XYZ
Post by XYZ »
Oh, and yes, I have heard a number of people on the a waves related thread [may be on the Waves forum] complain that the Waves plugs are losing settings.
I'm using Waves AU on an Intel machine with 5.12 and do not have this problem.
