4.6 crashes
4.6 crashes
Hi this my first time writing. I have a G5 2.0 dual w/6.5 gigs of ram, an IgniterX lite card,30 inch display, IR verb, Powered Plugins, Mach V, MX4, RMX, Real Guitar, Ivory, and a pci 424 card with (3) 2408's.
I just downloaded 4.6 and now my system has gone crazy. I created a file with 4 v racks, 3 tracks of audio 4 MIDI tracks and close to 3 plug ins per audio track (not a big file). When I start to do anything the file will play for a little bit then crash my entire system. Can't force quit, can't do anything but power down. Any ideas.
Tblanch
Tblanch
Re: 4.6 crashes
My OS is 10.39
- philbrown
Re: 4.6 crashes
Have you done any troubleshooting like trashing prefs and repairing permissions? Are you running the latest drivers? Some folks had to remove DP4.5 from their system or something - I don't recall the exact details 'cause I never had that problem. You might do a little digging and searching of recent posts or maybe someone will chime in.
Could also be a corrupt DP file or audio file. I'd at least try to create a new fresh file (not with these same audio tracks) and eliminate that as a cause.
HTH
Phil
HTH
Phil
Re: 4.6 crashes
To Dr Vague
I read some other forums, and I think I had a corrupt file. I've created a new file, and have not had any problems so far, but I've taken 4.6 out of my system. I might try to dowload it again, but now I have to finish a project first.
Thanks for getting back
Tblanch
Tblanch
- Timeline
Re: 4.6 crashes
You might try latest version of OS first or another drive with fresh instals of OSX.4.2 and DP 4.6 just for safety.
Re: 4.6 crashes
also try update_prebinding using terminal along with fixing permissions
Re: 4.6 crashes
Hi Ricebean,also try update_prebinding using terminal
Could you elaborate a little on that ?
Or may be just tell us where to find some information on this "prebinding update"
Thanks a lot !
Re: 4.6 crashes
pre-binding is a unix process that can help speed up performance. to do it: launch Terminal and run/type <update_prebinding> or when booting up start in single user mode by pressing Cmd-S at start up. at the command line type <update_prebinding> and press Enter. when done type Reboot and press Enter.
i do this as part of regular maint. i shut down my mac at night and the unix scripts don't have a chance to run automatically. also try Macjanitor to help with maint. hope this helps.
