What PCI firewire card would support 828mkii?
pheewee
Post by pheewee »
I tried to use my 828mkii (firewire) with ADAT as the potical I/O, but the CueMix does not let me with the error read: "The device is on a bus that does not support this transfer rate." This only shown when I selected ADAT I/O as the optical I/O. I am assuming that the PCI card that I used is not support the ADAT setting. I'm using an Iogear firewire 800 PCI card with the Windows default driver, which is shown as: Texas Instruments OHCI Compliant IEEE1394 Host Controller.
Any suggestions on what I should do to be able to use ADAT as optical I/O. Thanks!!!!
pheewee
Any suggestions, please help!!!
Post by pheewee »
Is there anyone out there using 828mkii firewire? If so what firewire PCI card (for PC) that you use? Any suggestions are appreciated.
BradLyons
Post by BradLyons »
As to what will or will not work, well that guess is as good as mine as it's impossible to stay on top of everything out there. I can tell you, however, that this card WILL work that I do know first-hand.
http://www.sweetwater.com/store/detail/FWCardPCI/
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
