I tried to use my 828mkii (firewire) with ADAT as the potical I/O, but the CueMix does not let me with the error read: "The device is on a bus that does not support this transfer rate." This only shown when I selected ADAT I/O as the optical I/O. I am assuming that the PCI card that I used is not support the ADAT setting. I'm using an Iogear firewire 800 PCI card with the Windows default driver, which is shown as: Texas Instruments OHCI Compliant IEEE1394 Host Controller.
Any suggestions on what I should do to be able to use ADAT as optical I/O. Thanks!!!!
What PCI firewire card would support 828mkii?
Any suggestions, please help!!!
Is there anyone out there using 828mkii firewire? If so what firewire PCI card (for PC) that you use? Any suggestions are appreciated.
- BradLyons
- Primary DAW OS: Windows
As to what will or will not work, well that guess is as good as mine as it's impossible to stay on top of everything out there. I can tell you, however, that this card WILL work that I do know first-hand.
http://www.sweetwater.com/store/detail/FWCardPCI/
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
Brad Lyons
db AUDIO & VIDEO
