FW daisychaining
rwchadwick
FW daisychaining
Post by rwchadwick »
I have a new intel macbook which has only1 firwire jack. Will I be OK daisy chining external drives lwith my 896 interface? Does it matter where in the chain the 896 is? Sorry, I'm not as bright as I used to be!:) Or do I need a FW hub? I've not had good look with USB hubs in the past, none of the MIDI interfaces will work with any I tried.
Noizemaker
Post by Noizemaker »
I do it all the time with my ibook and it's always been fine. ibook to the 896 to the HD.
rcannonp
Post by rcannonp »
I prefer to put the HD before my 896. If the HD is behind the 896, turning off the 896 will disconnect the drive.
gearboy
Post by gearboy »
Does FW400 read/write (aka track count) bandwidth suffer because of this? Obviously it's not a problem with a MacBook Pro since you can setup another FW bus with the card slot (how I run my PB/828mkii/Lacie D2 Drive).
Jeff
OS 10.4.11 - G5 Dual 1.8GHz, 3GB RAM / Mac PB G4 1.5GHz, 1.5GB RAM / Apogee Duet / MOTU 828mkii w/BLA Analog & Clock mod / MOTU DP4.61 / Live5.2 / Peak 4 & 5 LE / Izotope Oz3, Sp, Tr / Waves Ren Max / TRacks, Miroslav / NI Komplete 5 / GF impOSCar, MiniMonsta, M-Tron / Automat / Nomad Factory Vintage Studio Bundle / apTrigga / Audio Hijack Pro
My recording blog: http://www.ipressrecord.com
Resonant Alien
Post by Resonant Alien »
I don't know about the 896 - I tried this with an 828mkII and it did not work well at all. Now I have an RME Fireface, and daisy chaining works great. Seems the 828mkII must have some FW implementation issues.
