Raptor Drive update
TheCoalman
Raptor Drive update
Post by TheCoalman »
Well, there is definitely a problem with the 16mb cache drives and G5's. Things kept getting worse and I eventually sent the drive back. Do any of you guys know if the 8mb drives are more stable with G5's?
TheCoalman
G5 2.7 DP/10.4.11/3G RAM/DP 4.61/5.12/Mach 5 1.2/828/Express XT/UAD-1 4.2/Spectrasonics/EWSQ Gold/Sampletank 2.9
WSVP
Post by WSVP »
I posted this once before on this forum. There is a problem with some Western Digital drives with the G5 SATA interface check the link below. Your best solution if you already have this drive is to add a SATA controller card.
http://wdc.custhelp.com/cgi-bin/wdc.cfg ... faqid=1415
TheCoalman
I'm actually following up on an earlier thread I started, I told others who were interested from the thread that I would post results from what I heard from WD. What I heard was nothing....so I'm checking with some of the other users to see if the 8mb cache drives work any different. I'm aware of the pci card situation...thanks.
TheCoalman
willtompkins
Post by willtompkins »
I use the 8MB 10K (74GB) Raptor with no problems.
I have been using the 150gb 16mb cache Raptor on the internal SATA bus of a Quad G5 without any trouble since January. I use it as an audio drive, not a boot drive. I also have a PCIe Hi Point card hooked up to several external 76gb Raptors working fine. Reading the WD report referenced in this forum raises concerns, but since I have experienced no issues to date, I'll leave it set up as-is.
HC Markus
M1 Mac Studio Ultra • 64GB RAM • 828es • macOS 14.73 • DP 11.34
https://rbohemia.com
