Inexpensive USA Audio Interfaces with DP4
llamingo
Post by llamingo »
I'm trying to choose an inexpensive USB Audio Interface for a high school lab running DP4. I've been looking at the Edirol UA-1X and the Griffin iMic. (Wish we could afford better, but that's public education!) I know the iMic works with DP - does the Edirol? Any recommendations? Is the Edirol worth twice as much $?
Thanks for any help or advice!
Bill
FM
Re: Inexpensive USA Audio Interfaces with DP4
Post by FM »
whatever you do don't get the Edirol UA-20.
unless you are also in need of a shiny doorstop.
after the UA-20 fiasco (that's what you get when you try to cheap out) i got a Tascam US-224. i was very happy with it for a long time, not Hi Fi that's for sure but it gets the job done.
i never used it with DP though, i was using the horrendous Cubase at the time, so i can't vouch for it on OSX and DP.
cheers!
FM
FM has several amazing bridges for sale in the NYC vicinity.
shabbadoo
iMIC
Post by shabbadoo »
How did you get imic to work with dp 4.6?
Re: iMIC
shabbadoo wrote:How did you get imic to work with dp 4.6?
SHould be plug and play. Just select it in your audio hardware setup. Works great with my laptop.
shabbadoo
Post by shabbadoo »
I did but I get an error message, something about needing to configure the coreAudio?
shabbadoo wrote:I did but I get an error message, something about needing to configure the coreAudio?
Did you go into Audio/MIDI Setup and see if the iMic shows up? There may also be a driver online.
shabbadoo
Post by shabbadoo »
yes, iMac shows up, but when I select it, I receive a message: need to configure coreaudio to accept two channels. I dunno, sheesh.
acro
Post by acro »
Wow. I always thought that the UA-20 was one of the most stable USB devices around!
My main units are a 2408mk3 and RME HDSP, but I also keep a UA-20 as an emergency unit because it's stable and quick to set up.
mortvillefugitive
Post by mortvillefugitive »
Tascam US122 was my first interface, and it was halfway decent... $199. Two XLR ins, phantom power, and MIDI.
Logic 8, Dual 1.8GHz G5, 2GB RAM, 2X UAD1, AutoTune 4, 896HD and OctoPre, MIDI Express 128
