Inexpensive USA Audio Interfaces with DP4
I'm trying to choose an inexpensive USB Audio Interface for a high school lab running DP4. I've been looking at the Edirol UA-1X and the Griffin iMic. (Wish we could afford better, but that's public education!) I know the iMic works with DP - does the Edirol? Any recommendations? Is the Edirol worth twice as much $?
Thanks for any help or advice!
Bill
Bill
Re: Inexpensive USA Audio Interfaces with DP4
whatever you do don't get the Edirol UA-20.
unless you are also in need of a shiny doorstop.
after the UA-20 fiasco (that's what you get when you try to cheap out) i got a Tascam US-224. i was very happy with it for a long time, not Hi Fi that's for sure but it gets the job done.
i never used it with DP though, i was using the horrendous Cubase at the time, so i can't vouch for it on OSX and DP.
cheers!
FM
FM has several amazing bridges for sale in the NYC vicinity.
cheers!
FM
Re: iMIC
SHould be plug and play. Just select it in your audio hardware setup. Works great with my laptop.shabbadoo wrote:How did you get imic to work with dp 4.6?
Did you go into Audio/MIDI Setup and see if the iMic shows up? There may also be a driver online.shabbadoo wrote:I did but I get an error message, something about needing to configure the coreAudio?
