need an echo... echo...
- auptown
I am trying to find something to sound like the sort of echo / reverb that might have been used in the old girl bands; to my ear it's not a set of real clear and clean discrete echos, but something sort of spacier. Maybe it was some sort of tape delay.
I have UAD-1 including the Dreamverb and Plate, as well as Wizooverb W2, and of course the DP native plugs. The Delay plug in DP is the closest I have found, but I am looking for something different.
Any ideas would be appreciated!
MacPro 2x2.66, 5G ram, 1 SATA, 2 raptors, 2408 mk3, MOTU HD192, Mackie MCU
Dual 2.0g G5, 7g ram, 1 SATA drive, 1 IDE drive, Duende, Liquid Mix, UAD-1,
OS X 10.4.11, DP 5.13, MOTU 2408mk3, BFD, RMX, Atmosphere, EWQLSO Gold XP, Ethno, Grace m906, Blue Sky 5.1 monitors
MacBook Pro 2.13 3G ram, ext FW drive
- mikebeckmotu
http://www.audiodamage.com/product_info ... ducts_id=9
AudioDamage Dubstation
The examples on the site are obviously more extreme - as for dub music, but it can do subtle stuff easily, too. And price is right.
- sdfalk
There's some plugins in pluggo that might be what you're looking
for
www.cycling74.com
or:
http://www.u-he.com/filterscape/
for
www.cycling74.com
or:
- Spikey Horse
- Tritonemusic
- Kawentzmann
I think the Girlbands of the 60s either used a tile chamber, or in Phil Spectors case a recording room with reflective walls, or in smaller studios a tape echo.
There••™s also the combination of both (a room and a dedicated tape recorder) like early Gene Vincent and Duane Eddy.
To get the dirtyness of the old box in room with mikes through tube board sound, I would suggest using an amp-simulation software and good reverbplug.
Speaking of retro-echos, I have been looking high and wide for a plug-in that can do the cascading of several tapeheads, speaking of up to 5 heads feeding each other, like the old Dynacord tape-echoes of the 60s. Is it hard to program? There are patches for hardware-delays floating around, to exactly replicate any echo The Shadows used on their hits. But no software plugs - really strange!
KK
KK
single 1Ghz G4, DP 4.61, Tiger 10.4.10, Sampletank 2.1, Waves Renaiscance Reverb, EQ & Comp, PSP Vintage Warmer, Spark XL, PCI 324, Motu 2408 MKI, Amplitube
http://kawentzmann.de
http://www.lastfm.de/music/Kahuna+Kawentzmann/+albums
- kelldammit
- Primary DAW OS: Windows
- kelldammit
i thought only some of their plugs required dongles? i have the psp delays/filter and there's no dongle...
or is this going to happen with the ub updates?
kell
kell
- auptown
Wow thanks everybody for the suggestions. Really I was looking for what Kawentzmann (did I get that right?) was talking about, a multi-head tape delay, (but steroeo!) like the old school girl bands. I did try the Roland plug in UAD-1 but didn't like it, and I ended up buying the Filterscape and Audio Damage plugs and using a combination of them. It works, but was not exactly what I was looking for.
So any more thoughts about good tape delay emulators would be cool.
