realityloop wrote:Thanks Frodo.
Watching AUNetSend validate I began to wonder if it was a similar plug to RocketNetworks plug which made me quite excited. Thanks for the heads up AUnetsend I will read up on this and see what the upside is from an audio perspective.
As an update to my original post I have reinstalled Tiger and 5.1 from scratch and still have the same problem with AU validation, I can't figure out where I am getting it wrong.
My system has always worked fine with DP 3 forwards and I have never had any problems with installs. I still use a PCI 324/2408 II and O2R, never had any problems.
I'll just keep plodding away at it.
Cheers
Check for the file named "MachFive MAS. bundle'. Look at the date in the finder. If the date does not match the day you installed MachFive, then trash it and reinstall the MachFive v.1.2.3 update. Look for all '.bundle' files and '.component' files, perhaps even Preferences and Audio Unit Info Cache-- trash them-- reinstall a fresh copy of problem apps and then try the reinstall and reboot of DP 5.1 again.
I would consider doing the manual uninstalls first-- reinstalling DP and then reinstalling all else afterwards.
It may be necessary to go through all of your third-party plugins-- to do a manual uninstall of all bundles and components and then reinstall them. I struggled with this for days until I finally tweazed out the offending culprits.
The DP Installer's Uninstaller doesn't do all that it should, whether or not it does all that it was intended to do. Some things must be done manually on some systems.
By the way, I tip my hat to chrispick who led me in the right direction.
One other thing:
I have Logic and I admit that starting things up in Logic really helped to jumpstart things for DP, funny to say.
